Question about Lenovo ThinkCentre M57p Desktop - 9088BFU
Lenovo THINKCENTRE M57P 9088 - TOWER -1 X CORE 2 DUO E6750 WITH VPRO/ 2.66 GHZ
Well basically, I managed to pick up this machine today from a friend, I have seen it working but he had to take out the RAM, I put in mine and it just gives me a beep code it's like 1 Beep then 1second pause, then 3 beeps within a second, but I know there is nothing wrong with the RAM, it's being used in the machine that I am using now.
  • Lenovo Master
  • 2,878 Answers
Yes, but is it compatible? You need to research both.
Posted on Dec 07, 2012
Testimonial: ""It's simple you search: Lenovo THINKCENTRE M57P 9088 and it came back with http://support.lenovo.com/en_US/detail.p... The memory is listed there. You can aslo go to http://www.memorystore.com/ and use there self discovery for PC's running , or enter the make and model for manaul search. Now do the same with the other unmentioned unit. gl" Thanks for all your help!"
  • lkac_2010
    lkac_2010 Dec 07, 2012
    That's why I came here, I went looking, and could not find anything.
  • Jose Diaz
    Jose Diaz Dec 07, 2012
    It's simple you search: Lenovo THINKCENTRE M57P 9088 and it came back withhttp://support.lenovo.com/en_US/detail.p... The memory is listed there. You can aslo go tohttp://www.memorystore.com/ and use there self discovery for PC's running , or enter the make and model for manaul search. Now do the same with the other unmentioned unit. gl
Intel Core 2 Duo E6550 audio drivers
on the Lenovo support pages I found three audio drivers for your system (thanks for machine details) they depend on your o/s, and can be found here (select drivers > audio, you can you can type your os in the box to give only result)
http://support.lenovo.com/gb/en/products/desktops-and-all-in-ones/thinkcentre-m-series-desktops/thinkcentre-m57
18.December.2014
May 30, 2014 | IBM Lenovo ThinkCentre M57 - Intel Core 2...
M58P 6234 A1U
dear sir,
my machine mod.no.ams 210d hs
machine problam is err..no (axcept redy pogition) board heated disply
Oct 27, 2013 | Lenovo Thinkcentre M58p 6234-A1u Pc - Win...
Sound not working
The same model ThinkStation can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkStation, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Jan 20, 2013 | Lenovo THINKSTATION S10 6423 - TOWER - 1 X...
9088-a2u will not start
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps you
Mar 31, 2012 | Lenovo ThinkCentre M57p 9088 - Core 2 Duo...
Is there a better motherboard for the ThinkCentre M51-8143 which supports FSB 1333MHz?
If it was me i would be replacing the case as well then you will have no trouble finding a motherboard to suit. Will also be handy for any future work you need to do to computer. I doubt very much your old memory will fit in the new motherboard so why not get your memory upto around at least the 4Gig mark while youre at it. All this really wont cost much and you will have quite a nice computer which looks like new. Cheers from Scott and please vote
Oct 21, 2011 | Lenovo ThinkCentre M51 8143 Tower P4 531...
How do i find out which Lenovo model is my Desktop PC? Its a Lenovo ThinkCentre 9637-AA5.
1) Series:
It's a ThinkCentre M Series Desktop
2) Subseries:
ThinkCentre M55e
3) Machine Type:
9637
4) Model:
The Model Number will be right after ThinkCentre M55e-9637
It will be two numbers and a letter, or two letters and a number, or three letters.
Three characters. (symbol)
Some examples; 21B, 21H, 22U, 28s, 28y, B2F, B26, I2F, (i2F), I64, (i64), W2Y, W2Z, WJW, WJM
ThinkCentre M55e-9637-WJW
(Above is fictional. Just an example)
Regards,
joecoolvette
Sep 20, 2011 | Lenovo ThinkCentre M55e 9637 - Core 2 Duo...
How do i get underscore
press shift and minus (+) at same time then you'll get underscore
Aug 16, 2011 | Lenovo ThinkPad X200 Tablet 7450 - Core 2...
I need driver for my Lenovo ThinkCentre M58e 7298 Core Duo E8400 3 GHz desktop
Hi! Welcome to www.fixya.com.
Download and run the webcam driver from this site;
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers.html
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Lenovo ThinkCentre M58e 7298 Core Duo...
Lenovo ThinkCentre M57p Desktop - 9088BFU Logo
199 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
