Question about Car Audio & Video
I was turning up the lowpass button an the level
I was turning up the lowpass button an the level on the amp an they both jus broke i know how to sauter but i jus need the parts where do i get them
Sfe701xi sauter israel
Look them up in Internet Explorer or FireFox. I did not know they made computers.
Apr 02, 2014 | Computers & Internet
I am trying to install a amp and sub in my 08 gmc
dont need a diagram,, most amps have a speaker level input...dont mix this up with line level....connect your wires from back of factory speakers to speaker level input on amp...then if your amp has a low pass switch select lowpass setting now you have punch
Mar 29, 2009 | 2008 GMC Sierra 1500
Kenwood amp
Yes there is!!! I have that same amp and what probably happened to you happened to me, if you seen some black smoke or smelled like something was burning then heres what you do, Remove the cover under the bottom of the amp, there are alot of little screws so dont lose them!!!, you will see a wire that look like it ws fried and it will be broke apart, so get you a GOOD sautering iron and sauter the wire back together is you cant get it to sauder back then just take a piece of wire and tie the two broken pieces together and then your amp should work again!!
Sep 17, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Any ideas?
CHECK YOURE EQ OR TRY TO BYPASS THE EQ FOR TESTING
May 08, 2008 | MTX Thunder 1501D Car Audio Amplifier
Need to know the right setting to apply for my subs
You need to match your amp's input voltage (the gain) to the output voltage supplied via your deck's preouts. Turn you radio up to normal listening level, and turn the amp's gain until you induce audible distortion then back it off slightly. Set the bass boost and crossovers to on and type (highpass for front/rear full range or lowpass for subs).
Apr 26, 2008 | Jl Audio 12W3 Car Subwoofer
Protection mode
Disconnect all speaker wires from the speaker terminals of the amp. If it powers up and doesn't go into protect when you increase the settings, the wiring needs to be checked. If it still shuts down, the amp may need to be repaired.
Does it shut down or make loud noises when you move the RCA cables where they plug into the amplifier?
Mar 27, 2008 | Power Acoustik LT-980/2 Car Audio...
Need help bridging
First check your gain it may be turned down. I personally dont bridge speakers. I put each speaker to its own channel on the amp.Make sure positive to positive and negative to negative. Try hookin up two speakers to the amp (not bridged) and turn your gain up around half way. Make sure you amp is switch to lowpass not high since most amps have crossovers built in now. The more speakers you have the less output from each speaker from one amp youll get.
Mar 02, 2008 | Kicker 01C8VR4 Car Subwoofer
Treble come out with lowpass filter on
get it fix but sounds like a low current problem check cable connections
Jan 10, 2007 | Pyle PLA1485R Car Audio Amplifier
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
