Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Touch Pad Only the 7-8-9 pads work.
  • 242 Answers
Hello , your problem is the switch membrain , it sends signals to your control board.
you may be able to clean the ribon cable on the control board end but it may just need a new membrain.
The switch membrain is the part all the buttons are located on and they go out often on jenn-air ranges.
let me know if you have any further questions.
Phil
Posted on Jan 12, 2009
My. Compaq touch pad and buttons stopped working. Running win 7
ok, do you run 2 mice?
USB mouse,? or wireless mouse if yes that is the problem ,, is yes say so , we fix that. or remove that.
I cant see you PC so i must beg for facts.
did pc come with Windows, 7?
no PC stated. so..>????
to make the touch pad work, go to hp.com
go to your pc, unstated\
go to the OS , w7 for that PC,
and load the touch pad driver
if HP does no support your PC on W7 then that is a big problem
they can help you can they.?
so then we get more complex, we must find out exactly what touch pad you have ,then go to that maker and get a driver
is PC on the internet now.
yes.
then go to device manager,
click the touchpad listing and remove it or click update this driver.
if lucky W7 finds the driver best and replaces it.
and it now works, this is called Plug and PRAY.
May 28, 2017 | Compaq Computers & Internet
Hp laptop windows 7. touchpad locks for no reason. how do i unlock it?
Search for the button for PAD LOCK, of press Fn + some other buton to unlock...
and next time write pc model.
Jul 09, 2012 | HP Computers & Internet
I reinstalled vista 7 in my dell inspiron m5030 and the wireless internet and touch pad weren't working. I downloaded and installed all the drivers and the wireless internet worked but still the touch...
Try connecting an external mouse via USB port. If that works you probably need to have the palm rest (top plastic piece that contains the touch-pad and buttons) replaced.
Sep 01, 2011 | Dell Inspiron M5030 Laptop
Touch pad sony viao vpceb3j1e not working
Hey there. Often times this is a problem caused by accidentally turning it off. Look for a button on your keyboard or near the touch pad to turn the touch pad on/off. If you're using windows 7 and possible below, you won't need drivers to get the touch pad to work normally.
Jul 26, 2011 | Computers & Internet
HP 620 touch pad freezes after 2 hours of use, the laptop went 7 times to the service, the last time they changed the mother board (just 2 day's ago) and the problem still occurs. What can be the...
old 620 windows 7 loaded. 32 bit or 64??????????
8 years old now.
https://support.hp.com/us-en/product/hp-620-notebook-pc/4158863/model/4158501/manuals
use a USB mouse and forget the touch pad, ? option 1.
they broke the touch bad ribbon connector or its socket.
the touch pad can be bad.
this driver , 4th in the list mouse?
find a real shop that fixes things and not fix one and break others.
if the OS is not infected
and the HP real driver is there from HP not hackers or cloner bs.
then the pad is bad or cables not put back on it correctly
that is 3 possible.
it's really just 2, HW or SW (hard or software)
Feb 28, 2018 | HEWLETT-PACKARD 620 XT964UT Notebook PC
On the touch pad numbers 3, 6, 7 and 0 dont work
sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
Jan 27, 2011 | Sharp R305KS Microwave Oven
My Dell N4010 Laptop with Windows 7 software indicated a message of "touchpad disabled", and I can not manipulate the mouse.
You are confused. Your touch pad is disabled, but if you plug a mouse into the USB port, your PC will find it and install its software and you will be able to use the mouse To re-enable the touch pad, click on the Windows ball at lower left of desktop, Control Panel, Mouse, Touch Pad, Enable Touch Pad.
Oct 18, 2010 | Computers & Internet
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
Webcam and touch pad not working.
do an update on drivers through the asus website or the brand of webcam/touch pad
Dec 23, 2009 | ASUS G1SN-A1 Gaming Notebook PC
Jenn-air JES9800 error code F1-7
As indicated by others, the best solution for most people is to replace the touch pad assembly.
I went the cheap - time consuming route.
Jenn Air JES9800
Using the information from this forum and others I decided that the F1-7 error message was due to the touch pad. When I saw the price of the assembly which includes the touch pad I decided to take a look inside. With the power off :-) I disconnected the touch pad ribbon connector from the socket. Using a tool fabricated from a broken hacksaw blade hot bent 90 degrees about 4mm from the end, re-hardened and sharpened to form a knive edge, I carefully loosened the touch pad around the perimeter. The touch pad is applied to the frame with a flexible adhesive, so I was able to pull it off slowly without permanent deformation.
I softened the adhesive with odorless mineral spirits and was able to remove the adhesive from the touch pad with paper towels. upon examination of the touch pad I noticed several breaks in the the printed traces. I carefully pulled away the laminate near the breaks, which were near the flexible ribbon connector from the touch pad. I used a the copper powder paint from a Permatex rear window defogger repair kit to (tediously) paint traces to complete the gaps in the printed traces. The outer trace, which runs around the periphery of the pad kept showing a very high resistance (> 5 megohms) until I scraped away a short light colored section of the printed trace and replaced that with the repair paint. The trace then showed a resistance of just under 1meg. I temporarily re-attached the touch pad with tape and the error code did not reappear. I set the clock and successfully tested several buttons.
Next step - seal the area around the trace repairs so I can get some more years out of the stove, until the next repair.
The cause of this is an obvious design flaw. The printed traces were all compromised in the area where there is no discernable protection over the traces, allowing moisture (I assume) to react with the conductive material in the traces.
Mar 29, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
89 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
