Question about Dometic Refrigerators
Americana refrigerator a4425gdta ww
Is there a reset button on the freezer?
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Americana Model A4425GDTA-WW Replace Board in the
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 23, 2010
  • 4044 Answers
SOURCE: no light, no cooling in refrigerator, but cold freezer Americana A3316ABSDRWW
This usually means you have ice build up between the two units. Defrost the freezer and if possible let it sit to completely thaw all ice from the channels that allow cold air from the freezer to move to the Refrigerator side. You will also want to check your door seals to make sure you don't have any leaks or a bad seal causing your issue. The issue with the light is most likely a burned Bulb or bad switch. Replace the bulb and see if that resolves the issue. You also need to check and make sure the fans are working properly which move the air from the freezer to the refrigerator side and that all the cooling grill son the unit are clean and not clogged with dust build up.
Posted on Nov 25, 2011
Hotpoint HSS25GFPA WW Freezer not cooling
check for ice build up on evap coils ,,, bad efrost cycle
Oct 05, 2014 | GE Refrigerators
After a moving to a new city, we had our Hotpoint model HSS251FMD WW refrig in storage for 4 months. When I installed it in our new house it will not cool. Is there a reset button?
flush the refrigerant by nitrogen & refile new refrigerant.every work doing by qualified technician.my be some compressor oil over com in freezer
Jan 03, 2011 | Hotpoint Refrigerators
Model #GSS20IEMB WW. Neither freezer nor frig are cooling... all above 32 degrees. May have over-heated due to freezer door left ajar. Is there a reset button, or other solution to kick start it. Motor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 03, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
I left the Freezer door open and now it seems like the freezer is not cold enough to freeze things. It has been 5-6 hours since it has been closed. Is it just taking a long time to completely cold or...
Place a glass of lukewarm water on one of the freezer shelves. Leave the freezer door closed overnight. Check the water in the morning to see if the freezer has brought the temperature down. It takes quite awhile for refrigeration units to recover from heat loads such as door open for extended periods of time.
Jan 06, 2010 | Freezers
GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Jul 29, 2009 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
