Question about Canon PowerShot SX210 IS Digital Camera
Code error 19 when i connect my camera
When i connect the cannon camera i recieve the error code 19 in my device manager
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Dec 07, 2012
Why won't my camera connect to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
May 04, 2014 | Canon PowerShot SX130 IS Digital Camera
Can you connect a wireless camera to a wired system?
SIMPLE !! YOUR GONNA NEED A ADDNL ITEM CALLED A RECIEVER AND THERE SPECIFIC TO TYPE OF WIRELESS CAMMERA YOU HAVE SO CONTACT IT'S MFG FOR THIS DEVICE
Feb 01, 2013 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Computer do not recognize kodak c703 and the transfer station is not working
Hi
I just had this problem with my D5000. I did a lot of troubleshooting to discover a Windows Code 19 error in device manager. To see whether this is your problem, go to Control Panel, select device manager. Your camera should be listed under cameras/imaging devices. If there is a yellow exclamation mark, disconnect your USB/transfer station. Using device manager uninstall the software drivers. Once uninstalled reconnect the camera and usb or transfer station. Drivers are on the camera. It should begin an automatic reinstall. When it says your hardware is successfully installed, you should be able to use the transfer station again. If not, and you got a disc with your station, then I suggest uninstalling all the software and reinstalling. Apparently in windows operating system, if the registry entry relating to that device is damaging, it will no longer recognise the device nor load the drivers. The only way to fix the registry is to uninstall the device and reinstall.
good luck
Mar 02, 2010 | Kodak EasyShare C703 Digital Camera
Hi, i have a toshiba L355 S7812 and just upgraded to 7 -- everything seems to work except for the built-in camera, and i cant find a driver/program for it....the toshiba program from vista doesnt work....
If the Vista Driver Doesnt Work, You Will need to search out a Driver from Different Make/Model... OR install software such as Driver Genius or similar to Install the correct driver for you...Or... try uninstalling and rebooting..
1) Bring up the device manager. You do that by clicking on Start button and then type 'Device Manager' in the search box. Select the "Device Manager" in the list.
2) In the list of devices, you will see "Chicony USB 2.0 Camera" with yellow bang on it. You will see either code 19 or code 1 as error codes.
3) Right click on the device and then select "Uninstall".
4) In the uninstall dialog, make sure you select the option to delete the driver package from the system. This causes the driver package installed earlier to be deleted.
5) Then in the Action menu of Device manager, select Scan for Hardware changes option. This will cause the device driver to be reinstalled.
Nov 23, 2009 | Computers & Internet
Error Code 19
Replace the drive if it has not become unplugged.
Jun 26, 2017 | Computers & Internet
Hi i'm getting and error code 19 with optical drive
Error code 19 Is a registry problem.Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
Aug 31, 2009 | Televison & Video
USB trouble with SD1100is
Code 19 Your registry may be bad. (Code 19) To check your registry, click Check Registry. If the registry is bad, Windows will restart your system and go back to a previous registry that is good. Solution button: Check Registry This code means that the registry returned an unknown result. To resolve this issue, follow the recommended solution, which will run Scanreg.exe. If this does not resolve the issue, type "scanreg /restore" (without quotation marks) from a command prompt. Finally, remove the device from Device Manager, and then redetect it using the Add New Hardware tool in Control Panel. Hope this help's ;)
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Toshiba laptop will not pick up canon camera from any usb port
suspected the driver got error.
-go to start, point to computer, manage, click device manager.
-under device manager check whether you see an exclamation point on usb devices
-if yes, you need to re-install the usb drive of your machine
May 22, 2009 | Computers & Internet
How to solve the code 19 errors
Error Code 19 means that the registry is corrupted. Try the following fix:
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters. On the Edit menu, click Delete.
  5. When you are prompted to confirm the deletion, click Yes.
  6. In the right pane, click LowerFilters. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. Exit Registry Editor.
  9. Restart the computer.
If this does not work, try uninstalling and reinstalling the computer by:
  1. Click Start and then click Control Panel.
  2. Click System and Maintenance, click System, and then click Device Manager.
    In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
  3. When you are prompted to confirm that you want to remove the device, click OK.
  4. Restart the computer.
Nov 22, 2008 | Sony (2450455) CD-ROM Drive
Canon PowerShot SX210 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
