Question about Yamaha Full-Size Keyboard
Keyboard doest work
I brought a Manhatten Wireless Keyboard and two . I can't get the ID code. the mouse seem to work but the keyboard does't
    President:
  • 8,637 Answers
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Posted on Jan 16, 2009
Keyboard display light dim,keyboard seems frozen,nothing working
Power supply circuit is malfunction.
Chances are, there is a voltage which is still working, but it is not normal and is not in accordance with the required voltage.
Mar 24, 2015 | Music
Keyboard won't play
Try: turning off keyboard and restarting the computer.
Start up Novation until completely loaded.
Switch on keyboard the set id ports....worth a shot(?)
Keyboard communication can be temperamental when interfacing with computers. Especially when dealing with audio problems, latency problems, inputs and outputs.
Follow the directions specifically in the Novation Manual...it only takes one wrong step to stuff the whole thing up ! :)
Nov 26, 2013 | Novation Music
I brought a akai mpk mini and when i plug it into my laptop, the sony vaio ns-series VGN-NS30E says i need driver software to use it. the keyboard works on my computer though (dell volstrom 220 mini...
Your machines are different and likely have different interface chipsets. Some newer machines have more built in plug-n-play than others. There is so much incompatibility that it is a wonder that any of the stuff works together. You need to install the needed driver... NOTE: there is a lot of incompatibility between OS versions... so if for instance you are using XP on one machine and Vista or Windows 7 on the other there are a LOT of incompatibilities. ALWAYS check the requirements for the computer with the specs of the device to be connected. MOST of the problems are due to OS variations. Check for driver updates on the Sony site
Jan 29, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I have a Yamaha PSR-170 that has a jammed key
Most keyboards of that scale are not especially fragile. You may have to remove the back (lots of screws) and maybe a bezel that is across the top of the keys to get full access to the keys. The good thing is you have lots of working models --- all the other keys. So carefully consider the differences. It may be that one or more plastic parts have broken, particularly if it fell and landed with pressure on that key.
Most of the keyboard manufacturers have parts departments that can supply just the part of the keyboard you need if you can specify exactly what you want.
Sep 19, 2009 | Yamaha Portable Keyboard
Displays code Scn
Either the keyboard is disconnected or the Keyscan on the keyboard itself is but. More than likely a loose connector.
Jun 02, 2009 | Yamaha Music
Yamaha YPG625 screen shows only vertical lines
I brought the keyboard into a local service technician. He told me that he had to remove about 50 screws but the solution was simple. He unplugged and reconnected the ribbon connector. It apparently was not making good contact.
Oct 02, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
91 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
