Question about Tomtom ONE GPS Receiver
Does the Via1430/1435 have a reset button
Device is locked on screen, map won't work with this device, tried holding button until drum roll is heard but still won't reset
    Sergeant:
  • 316 Answers
There seem to be numerous users that are having similar problems with this model. I suggest you contact TomTom user support and let them walk you thru the steps to resolve the problem.
Posted on Dec 07, 2012
  • 503 Answers
SOURCE: tomtom one will not turn on. Will eventually
Powers on then off is usually a sign that the battery in the unit is no longer holding a charge, i would suggest that you check the battery and make sure that it is holding a charge and if not, change the battery out, these gps units have a dead circuit in them, if the battery is no good then usually the unit will not turn on, also for testing purposes if you pull the battery then try powering up the unit it may turn on, if this happens then you know the battery needs to be replaced.
Posted on Jun 12, 2010
E61N
  • 515 Answers
SOURCE: TomTom GO 720 - flashing red circle with white cross on screen
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
Posted on Jan 27, 2009
E61N
  • 515 Answers
SOURCE: no maps found! displayed on screen
http://www.tomtom.com/support/index.php?Language=1&query=no+maps+found&FID=9838
Posted on Apr 13, 2009
SOURCE: continually returns to demo mode
I had to contact TomTom to answer this, their advice was:
On your device tap the bars that show the strength of the satellites. Then top right tap the clock and hold for 30 seconds.
I tried this but it didn't make any difference to me, but I thought it may help other users. I'll let you know when I get any further advice.
Regards,
Sean
Posted on Jun 19, 2009
  • 567 Answers
SOURCE: I have just paid for
Hi it seem as if that map was not design for New Zealand to be sure you should contact the seller about the problem.
Posted on Jul 25, 2010
How to disable tomtom nb1 screen lock
Hold the power button for about 20 sec until you hear a drum beat. this will reset your device
Mar 03, 2015 | Tomtom GPS
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
It was working fine and when I tried to use it the next day it is now stuck on hte loading maps screen and will not fully boot. I have tried to hold the start button all the way to the left to reset it as...
It will be hard to give a solution not knowing what model GPS you have. usually there is a recessed reset button on the bottom of the unit, or near where you plug the charger. Use a paper clip to press it in. Also some units you need to hold the power button in until it resets. If neither helps, please give me the manufacturer and model number so I can give you better assistance.
Aug 10, 2011 | GPS
Garmin Nuvi 205 - when I switch it on the maps load up and after the warning screen a screen appears with the message "Stay up to date with your Garmon Safety Camera Data at my.garmin.com" I try...
You probably need to update the unit at their website. In the meantime, you can try the reset button There is one, but it's kind of stealth - it's on the angled edge of the bottom of the device, in a square "hole". Pressing the corner of the screen resets user data only, not the actual device. Good luck!
Apr 29, 2011 | Garmin nuvi 205 GPS Receiver
Comes on white screen then off just for a second
If possible, try to restore the device to the newest firmware on it using your computer using this firmware:
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-18C/Downloads/LCX-18C-Software-Update/
OR
Do a soft reset. This may resolve your issues and will also keep your data on the device.
Do a soft reset by:
1. Having the device already off
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
If neither of those work, try a hard reset. This will however delete all stored data off your device.
To do a hard reset:
1. Have device off
2. Press and hold the ZIN&ZOUT Keys at the same time
If none of these work, contact Lowrance at 1-800-628-4487
Mar 05, 2011 | Lowrance LC X-18c GPS Receiver
Garmin Nuvi 1350 - will not power on unless I hold power button down for the 10 second reset. At this point, the device powers on until it reaches the "loading maps" point and then shuts down.
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
  • The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
  • Market Name: On the Road
  • Serial Number (listed on the bottom of the device)
  • Question Type: Repair Information
  • Provide a short description of your problem or question: nuvi frozen on Garmin Logo
  • Full Name
  • Contact Phone Number
  • Shipping Address
Nov 11, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin starts loading maps, then screen goes blank
First do the master reset -Hold down finger in lower right corner of screen and press switch on button. Hold still until asking of erasing all private data appears. FAST click on YES.
If it doesnt work:
From www.garmin.com -cllick on SUPPORT -> SOFTWARE
Get webupdater and install it. Run it and you'll find button "Find device". Of course you can't because it does restart all the time.
Hold down finger in UPPER LEFT corner of screen and press switch on button. Hold still for about 10 seconds (GARMIN appears and nothing more) and fast connect the USB.
HOLD switch until icon of connected computer appears on the screen. After then device stops resetting.
Webupdater can find your device, and now you can put a new firmware by doing step by step instructions from webupdater.
wildadam
Jun 19, 2010 | Garmin nuvi 1350 Car GPS Receiver
Just get white screen won,t turn off
Hold the power button down for as long as you can until you hear drums play.
let go of the power button once you hear the drums.
and see if your device boots up properly
cheers,
Pabz
Sep 23, 2009 | Tomtom XL 330 Car GPS Receiver
Dell Printer 1720dn - Unable to reset drum counter..
"Press & hold the cancel button untill all lights start flashing in a sequence and then i release the button and close the front cover." "DO NOT release the button, but continue to hold down it while you close the front cover.
Printer offline: Right click on your printer in the "Printers and Faxes" folder and "UN Check" use printer off line,
May 11, 2009 | Dell 1720dn Laser Printer
Tomtom ONE GPS Receiver Logo
181 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
