Question about RCA HD52W56 52" Rear Projection HDTV
How to access the convergence option on rca model HD52W59
    Top Expert:
  • RCA Master
  • 14,553 Answers
The customer one is in the main menu, the advanced one is rather hard to get to; Note if the Convergence option is missing from the main menu you have an issue under the High Voltage transformer or right next to it--this set is well known for this and a "kit" with a diode, cap, and the protect coil is available on the internet.
If you go after that resolder all the connections for the Sweep transformer and right around it, bad connections seem to start this kind of problem and no point in replacing parts if you do not also resolder----Good old Lead free solder.
Posted on Dec 07, 2012
Slinteriors
  • 8617 Answers
SOURCE: RCA HD Projection TV Model HD52W59
you have a fusible link that has blown. This is what causes the convergence option no be erased from the menu. You will need to locate the blown link and replace it. They are identified by FLpreceeding the location number on the circuit board such FL221 and etc.
Posted on Mar 23, 2008
  • 8457 Answers
SOURCE: RCA HD52W59 TV Convergence problem
Yes,not difficult.Covergence have an open Fuse(FL231)located right side of the FBT.
There is 3 in a roll small brown rectangle loking caps,but they are fues it the one in the middle is dead needed to be replace.
Posted on Aug 25, 2009
  • 668 Answers
SOURCE: convergence option missing from set up menu rca
Usually if something is missing from the main menu or no longer listed in the menu, is because the Main EEPROM has crashed. To get the right replacement, you will need to have the Chassis number, (CTCXXX), at the time of order. You can order it from Encompass Elect. at 1800-638-3328.
I hope this helps
Skyassoc
Posted on Nov 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: my convergence keep going out, I replaced the
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Posted on Nov 27, 2009
ladywinn
  • 5138 Answers
SOURCE: My RCA HD52W59 HDTV has a convergence problem. It
On your Deflection Board it is the bottom left hand side board has FBT flyback transfomer on it Blowed Fuse FL231 it will be on right hand side of FBT there is 3 of them in a roll small brown rectrangler looking caps but they are fuses ir will be the one in the Middle Call PartStore.com 1-866-925-7278
Posted on Dec 31, 2009
Dec 31, 2009 | RCA HD52W59 HDTV Projection Television
Where are the convergence chips and resistors (pico fuses) located in the rca hd52w59 hdtv projection tv?
There are none in that chassis. You can get the convergence option missing repair kit at the following link and the kit contains the parts and CD with instructions. www.tvrepairworld.com
Sep 12, 2009 | RCA HD52W59 HDTV Projection Television
My picture is not fitted to the screen.
go into the menu find convergence
some models have auto convergence
if you have the option to manual adjust convergence adjust red and blue DO NOT move green
Sep 02, 2009 | RCA HD52W59 HDTV Projection Television
Convergence needs to be reset.
thats a easy and inexspensive repair. there is a repair kit called the ITC222 and ITC222A convergence option missing repair kit which will usually fix that issue. You can get the kit which has the parts and detailed instructions at the following link. www.tvrepairworld.com under their RCA repair kits category.
Aug 08, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 convergence problem
Point-by-point convergence can be set by a good technician, but the controls are not accessible to the customer. also check the fuse in the power deflection board.
Jul 26, 2009 | Televison & Video
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Convergence
is this the same convergence problem in your previous post.. no convergence on a hd52w59? no convergence option in setup?...fl231 a small fuse next to flyback being blown causes this. The reason this blowns is poor solder connections on the flyback
Mar 23, 2008 | RCA HD52W59 HDTV Projection Television
Mar 23, 2008 | RCA P61927 61" Rear Projection Television
Conversation
The service # is hd52w59 and then something like yx1 or etc..... On the model # tag, this is written in very small writing. There is no way to remove the convergence option. Go to menu the set up and there you should find convergence. Choose convergence and run auto converge. If this does not work then there is a failure on the convergence power supply, convergence amp, or the deflection/power bd.
Mar 19, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W56 52" Rear Projection HDTV Logo
19 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
