Question about Lands Phones
I have NEC-ESPILA EX Model no. IP1WW PSU-C1 EPABX installed in my Office, Does this device has options to select different kind of Dial Tone I wish to activate on my choice, is their any list of Dial
I want regular Dial tone to be active on my NEC-ESPILA EX Model no. IP1WW PSU-C1 EPABX as lot of service provider offer PRI with their own dial tone tunes, So can i select any dial tune from the option this device provides? Is yes then how can i select the same?
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
  • 84 Answers
SOURCE: Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Posted on Feb 27, 2009
SOURCE: no dial tone on a nec dtu
The NEC phone is probably a business multi-line digital phone, requiring a phone 'back-end' system. Will not work on an analog 'home' phone line.
Posted on Mar 06, 2009
SOURCE: GE 2.4 ghz card less phone
change langugeon a 27923 GE cordless phone
Posted on Mar 12, 2009
SOURCE: GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Posted on May 07, 2009
Fax to 1-815-346-2473 on my SF 650 machine?
Dear
first check the no 1-815-346-2473 with your telephone company. In the said model there is a handset. do -lift hand set here the companys dial tone dial the required tel. no. here the Rx.tone from the other fax machine connected. If its working definitely your fax machine will transmit the data.
If the fax machine has connected behind EPABX, it has unique no. to dial out side of the epabx. In that case contact your EPABX provider to program the fax machine.
Thanks.
Dec 18, 2014 | Samsung SF-650 Laser Fax Machine
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
I was cleaning my phone and I pressed on something and now there is music playing that i can not stop,I don't know how to stop the music,my phone is panasonic KX-T7730
Here are two methods to turn off background music, one of these should work depending on which Panasonic phone system your phone is connected to.
1) With phone idle, press the 1 key on the dial pad (turns off background music when it is on and turns on background music when it is off).
2) With phone idle, press intercom button then dial *751 on the dial pad followed by 0 on the dial pad to turn off background music(confirmation tone will be heard) and end by lifting handset and replacing in cradle. To turn background music on, press intercom button then dial *751 on the dial pad followed by 1 or 2 on the dial pad to select the background music source(confirmation tone will be heard) and end by lifting handset and replacing in cradle.
Feb 05, 2011 | Panasonic KX-T7730 Corded Phone
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
I have installed Skype 3.8 and d-link driver 1.01 on Windows xp. I can select the device from the audio setting but receive no dial tone. Please assist!
In your VoIP monitor settings there are two options to make your phone connect to voip. You either have to dail # # or # *. I would try hitting pound twice, but it's kind of tricky because sometimes when the dlink tries to connect it will flip back and forth between voip and pstn. So I recommend holding the phone to your ear and hitting # until you hear that dial tone!
Jul 01, 2010 | D-Link DPH-50U IP Phone
Our office has a NEC multiline phone, and line 9 is lit up green, but when accessing it, there is a busy tone, how can I clear that line?
Easiest way is to unplug the system, wait 20 seconds, and plug it back in. If it's still lit, maybe there's no dial tone on the line.
Carl
Jul 06, 2009 | NEC DSX Super Display Phone BLACK
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
How do I get a message arlet tone on a blackberry 8700v smartphone?
Want to change the tone you hear when you get an SMS, MMS, or IM? Want to change the ringer for the phone? Follow these directions to edit the Profiles area on the device:
1. Select the Profiles icon
2. A box will appear where you can quick select between Loud, Vibrate, Quiet, Normal, Phone Only, and Off. If you wish to quick change the device profiles then select the one you want and exit out.
3. If you want to edit the tones assigned to the device applications then select the last option, Advanced
(some older models and OS 4.1 and below will not have the "Advanced" step--if Advanced is not present go directly to Step 4 below).
4. Select the profile you wish to edit. (Loud, Vibrate, Quiet, Normal (default), Phone Only, Off)
Note: on the 8100, 8800, and 8300 models: Do not click the trackball. Instead, click the menu key to the left of the trackball).
Note: The profile that is in use will say: (Active)
5. You will now see a list of all applications that can have a tone assigned (Browser, Calendar, Level 1 Messages, Messages (email@domain.com), Messenger, MMS, Phone, SMS, Task ect..)
6. Select the application you wish to edit the tone / notification for
7. You can now edit Out of Holster and In Holster tones/ notifications.
a) Select between: None, Tone, Vibrate, Vibrate+Tone
b) Select the Tune you wish to use
c) Select Volume (options are Mute, Low, Medium, High, Escalating)
d) Select Number of Beeps (options are 1, 2, 3)
e) Select Repeat Notification (options are None, LED Flashing)
f) If set to Vibrate or Vibrate+Tone then select Number of Vibrations (options are 1, 2, 3)
8. Repeat a-e for each of the desired applications listed in 5 above
Good luck. If this helps you plz rate this. Thank you kindly.
Jan 31, 2009 | Cell Phones
NEC IP1WW-24TXH
For the NEC you will need to have an NEC Technician enable this in programming or if you were given all the manuals when you purchased the system you can enable this option in the Class of Service area in programming.
Dec 11, 2008 | Lands Phones
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Lands Phones Logo
254 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
