Question about IBM xSeries 345 Server
I am setting up a Xseries 345 server using ServerGuide 7.14 everything runs fine untill it start to copy files it than gives me a blank screen and nothing happens after that
    Scholar:
  • 143 Answers
This is probably a Server Guide issue. You may check with one step lower verion and one step higher version of server guide. It may solve issue.
If that doesn't work, you may have to manually install OS without server guide. You can use a either use a floppy drive or pen drive to load controller driver. Once installed, rest of the drivers can be downloaded from IBM site or install from server guide cd
Thanks
Posted on Apr 10, 2014
  • 58 Answers
SOURCE: Install windows xp on a IBM xseries 200 8479 computer
You have to download the scsi driver from the ibm site. You'll need a floppy and floppy drive. When you boot with your xp cd to setup press F6 to install driver.
Link to your IBM. Since IBM have different models you have to type it at the provided link.
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/brandmain?brandind=5000008
good luck
Posted on Dec 21, 2007
  • 17 Answers
SOURCE: xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Posted on Nov 06, 2008
  • 36 Answers
SOURCE: how do i get a IBM Xseries server to recognize a serverraid card
IBM Serverguide will most likely get you going again. Go this link:
http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?lndocid=SERV-GUIDE&brandind=5000008. You can download the ISO image for the version of Serverguide that will let you configure your system. If you have a Xseries 360 version 7.2.03 should work.
I hope this helps. Good luck!
-jodair
Posted on Apr 06, 2009
  • 93 Answers
SOURCE: SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Posted on May 19, 2009
dante777
  • 623 Answers
SOURCE: IBM eserver xSeries 220 ServerGuide
Check this link for the latest version.
I didn't upload it, so it is possible that the link disappears.
Posted on Oct 28, 2009
Why xseries 336 has blank screen, starting but not booting
If your computer won'r boot, you have a problem with your Hard Drive or the boot system of your drive. You should have an emergengy disk/CD to access your computer for this case and repair boot or check integrity of your drive. No way to help you by answering a question
Sep 04, 2014 | IBM eServer xSeries 336
We are using KM 4050. Everything is fine, We can print, copy, but we cannot scan to email. It started yesterday. I check all the setting, cable, I even change to use gmail SMTP server. it still gives me...
You cant can to email using gmail server. they have hundreds of different servers. would reccoment setting up scan to folder either to a shared folder on your server or straight to your c drive if needing some confidentiality
Oct 16, 2013 | Kyocera Km-4050 With Feed, Finisher, Bank,...
IBM xSeries 235 8671-1AX Changed defective
Was it an exact like for like motherboard you replaced or a different one? Because if it is different then you may need to reinstall windows (assuming that is what you are using), it doesn't like new hardware just being added too much.
Aug 19, 2013 | IBM eServer xSeries 235 (867131xj)
I have a Xseries 345 server and the USB port is not working
Update bios, reinstall Chipset driver else use external USB PCI card
Apr 02, 2012 | IBM xSeries Computers & Internet
How do i get a IBM Xseries server to recognize a serverraid card
-jodair
Apr 03, 2009 | IBM eserver xSeries 360 8686
Oct 21, 2008 | IBM eserver xSeries 220 8646
IBM Netfinity 5600 8664 81Y Server
The disk that comes with the machine is called the NOS in the manual. It is also known as ServerGuide 6.0.3 which will config your Netfinity up to Win2000 Server. I used ServerGuide 7.3.06 to install Windows 2003 Server. The latest version (IBM ServerGuide Setup and Installation CD v7.4.17) is on the support IBM web site:
http://tinyurl.com/5fmv5k
Sep 21, 2007 | IBM Netfinity 5600 8664 Server
IBM xSeries 345 Server Logo
211 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
