Output comes then decrease the output
When we switch on the smps (230v) output comes (5v,12v,-5v,-12v) suddenly decreses the output i.e.power shutdown problem
  • Computers & ... Master
  • 5,660 Answers
That's because the Electrolytic Capacitors inside the SMPS are breaking down.
Specifically Radial Aluminum Electrolytic Capacitors.
A Capacitor slowly builds up a charge, then releases it all at once.
(Although it happens in milliseconds. Millionths of a second)
Think of a large swimming pool being filled up by a garden hose, then one wall is taken down all at once.
Capacitors are used in flash units for cameras. (Slowly being phased out)
The basic construction of a Radial Aluminum Electrolytic Capacitor, is;
A) Outside case: Thin aluminum. Like a Coca-Cola can with the top, and bottom cut out.
B) Top: Thin aluminum flat disk. Has a lK or X shape etched partway into it.
This is the Vent Cover.
C) Bottom: Thin flat synthetic rubber disk. The Positive and Negative lead pokes through it.
This is the Bung.
D) There are three strips inside. (Basic construction)
1) One strip is of foil thin metal, and has the Positive lead connected to it.
This is the Conducting strip.
2) One strip is also thin foil metal, but has a non-conducting medium applied to it. It has the Negative lead connected to it.
This is the Non-Conducting strip.
3) The last strip is a paper-like medium, and is soaked with Electrolytic Paste.
The paper-like strip is laid in-between the two metal strips, and all three are rolled up tightly.
There are many layers of this construction inside the capacitor.
When the capacitor starts to fail, it's because the Electrolytic Paste inside is developing gas. Hydrogen Gas.
The gas expands inside the capacitor's case, and the build-up of pressure eventually compromises the seals.
Either breaks the lK or X shape open in the Vent Cover at the top, or pushes one side of the rubber-like Bung down.
Electrolytic Paste starts oozing out.
So much paste loss, and the capacitor operates in a weakened state. Too much paste loss, and the capacitor fails.
Capacitors are used as Filters inside the Switched- Mode Power Supply,
http://en.wikipedia.org/wiki/File:ATX_power_supply_interior-1000px_transparent.png
http://capacitorlab.com/visible-failures/index.htm
This is NOT an invite to open the Power Supply, and attempt repair.
Regards,
joecoolvette
Posted on Dec 07, 2012
3 Suggested Answers
SOURCE: My pc cannot turn on.
Get yourself a new one with new power supply new quad core new hard one terra evething new for a few dollars time change computers are something very different nowadays nothing to do with 10 years old machines....enjoy todazy life is not forever...;
Posted on Aug 19, 2009
  • 57 Answers
SOURCE: ISO 400 Power Supply 300W Description
Acquire a replacement power cable simialr to the one missplaced.
Posted on Dec 22, 2010
TV will not come on even though the light turns blue
check for leak or bad capacitors in the power supply board, then if you can make a voltage checking just to ensure if output voltage in the power supply board are present. the 5v standby 5v switch 12v and 24vdc at the power supply doesn't drop.
Sep 03, 2012 | Televison & Video
LG VCR power up problem
check smps volt +12v, -12v, 5v,3.3v, -22v.mast be have +12v, -12v, 5v.if not change or" connect extranal smps.
May 30, 2012 | LG Televison & Video
My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
My computer isnt powering up, what should i do?
r u a professional..??
assuming that ur bios is not flashed, in a wrong way..
all fuses to mains supply are ok, including all wiring circuitry..
if so check--
the system battery for above 3.0v
all smps output signals are ok..ps-on(green +5v);
pg(violet~+5v) & sb(grey~+5v); (orange~+3.3v);
yellow (+12v); red (+5v); white (-5v); blue (-12v);
ground (black~ 0v)..
the cpu..
..replace the smps/cpu/battery with standby n check..
..contact ur system admin/vendor....
Oct 27, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Aug 19, 2009 | HP Hewlett Packard Pavilion Slimline...
ASUS P5GL-MX performance
Install new power system!
Thanks,]
Melcom Smit
Oct 04, 2008 | Computers & Internet
HP DESKTOP COMPUTER
If computer is not powering on then open u r cpu and check the SMPS i.e Switch mode power supply which converts AC to DC it gives a output of 5v & 12v in that the 20 pin or 24 pin connector which is connected to the mother board remove that and short the wires Green and Black and make sure to remove all the power connectors i.e,hard disk,Cdrom or cd writer or DVD writer or any other device and one more connecto which is a four pin connector which is connected to the mother board please remove and test the 20 or 24 pin connector by shorting green and black and behind the smps u have a power cord of ac 220v just plug it and switch on if smps fan rotates that means it's fine then the problem willbe on the mother board just try this
Jul 30, 2008 | Computers & Internet
My Computer does not work at all.
more than sure if you have replaced the power supply already and the computer still not working,there must be a electrical damage to the board.
it is sure that.but you have to check some other components too seeing that they are stuck in the board,like the procesor and ramm dims or the video card..the electrical charge may have affect them too.
but 1st thing to do is to change the mainboard..
oh by the way...just to be sure..try to make a bios reset..maybe it will work and pull out the ramms from the computer..put them back after...ussualy this works...
good luck and let me know about
bye
Feb 03, 2008 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Computers & Internet Logo
David Payne
David Payne
