Question about Dryers
It isn't turning on
    Top Expert:
  • Dryers Master
  • 9,472 Answers
No heat or not spinning?
Posted on Dec 07, 2012
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
1994 buick roadmaster temp light keeps turning on & off, but car isn't overheating, what can it be? What's your problem?
Usually a sign of a problem with the temp sensor or the wiring harness back to the computer.
Oct 13, 2012 | Buick Roadmaster Cars & Trucks
The touch screen on my iphone isn't working. I can't turn it off because the touch screen is required to turn it off. Any advice?
You could try to reboot your phone by holding down the power button & the home button simultaneously. That may help.
Sep 20, 2011 | Apple iPhone Smartphone
My 2001 Sienna shakes when I apply the brake. I don't know the problem. It passed inspection so I am assuming it's not the brake. Please advise.
The car isn't driven when inspected
Your only choice is to recall, if you had the
brakes apart every year, to clean off rust,
inspect,lube & if necessary machine or replace
parts.
You can not drive year after year & not have
braking issues.
Some times the work you pay for isn't done
correctly & they put issues in there.
Never assume anything in life
Always inspect or test things,& trust no one
Jul 12, 2011 | 2001 Toyota Sienna
So after getting my car back for the garage my subwoofer isn't working I checked to make sure all of the connections are correct and the settings are there why won't it work
Check to see if your amp is on. You may have blown a fuse somewhere maybe on your amp. Check for proper voltages and make sure the sub isn't blown by pushing on it. If you feel unequal resistance, you probably blew it. Also check the ohms on the woofer.
Jun 06, 2011 | Car Audio & Video
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
For the past 2 weeks, when I try to start my 2003 Nissan Xterra, it seems sluggish, but the engine will turn over. On 2 separate occasions, when attempting to start the engine, it wouldn't turn over ...
Checked Cables how?
Looking & Touching isn't doing anything
You have to do a voltage drop test or remove
& clean the ends. I would do both
Remove the starter & have it tested at parts store,
assuming you don't know how to do a voltage or
current test while cranking.
May 24, 2011 | 2003 Nissan Xterra
I Have an spl audio amp 520 watt and when it turns on it automatically goes to red which is protect. what could be causing this problem
It could be 3 things. There could be a short somewhere, your ground isn't strong enough, or you accidently switched up the ground line and the power line on the amp. Since the fuses aren't blown I would say that your ground isn't strong enough.
May 01, 2011 | SPL Car Audio & Video
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
