Question about Muratec F320 Plain Paper LED Fax
I'm noticing black streaks in my copies, how do i clean it?
+ my copies come out with streaks from top to bottom portrait style printing.
    Sergeant:
  • 316 Answers
Open the feeder from the top of the machine...you will see a thin strip of glass maybe 1/2" wide running from the rear of the machine to the front..odds are there is glue/dirt/corrector fluid or some other dirt on the glass. Clean this off.
Posted on Dec 07, 2012
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Black streaks at bottom of page after printing
Okay Grehner, I suggest you to perform a complete alignment and cleaning/maintenance-service for this printer.ASAP...this will help you out with this particular problem during printing.
Blessings.
Gladmar.
Mar 18, 2014 | Savin Office Equipment & Supplies
Copy streaked
try to clean the print , by print clean print head
Sep 06, 2013 | HP Officejet Pro 8600
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hi, I have a black line that runs from top to bottom of the page when scanning, faxing and copying. How do I fix this issue?
the blcak line that runs from top to bottom is due to a dirty misaligned print head...do a full printer maintenance on your printer/scanner . Once the heads and rollers get clean and the printer is aligned, it should get rid of any black streaks or lines. I own a Brother Printer/scanner and it did the same thing to me, as soon as I ran maintenance on it..it fixed the black straks and lines I had on my prints.
Jun 18, 2010 | Brother MFC-9420CN All-In-One Laser...
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Canon MF5750--copies come out with black streak (smear) from top to bottom of pages when printing. Changed cartridge and cleaned window.
run twenty blank pages through the printer by printing just a period (.) on a document. Otherwise the sheet should be blank. This is a way of cleaning the toner or inkjet ink from the printer. By the time the twentyth page is printed, the page should be clean. If not, you may have to get the printer serviced. The canon service number is 1-800-423-2366 option 1.
Jan 28, 2010 | Office Equipment & Supplies
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Black stripes
There has probably been spilled some toner inside the printer. You might be able to have it cleaned. It also might just wear off, but that will take some time. If the printer has toner cartridge with a drum inside, changing it might help.
May 16, 2007 | Samsung CLP-500 Laser Printer
Muratec F320 Plain Paper LED Fax Logo
117 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
