Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Laser jet 1536 error de memoria 10.1000 - HP LaserJet M1522nf Multifunction Printer (CC372A)
seeker5211
  • 1089 Answers
SOURCE: hp laser jet 2420d erreur 57.03
One of the printer fans is bad. The main fan is found at the lower front right side of the printer and the sub fan is found on the left side of the printer. Try putting your ear against the center left side cover and then the right front side cover. You might be able to hear or not hear the fans. Of course if you know how to remove the covers, you could look.
Posted on May 10, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
  • 38 Answers
SOURCE: I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Posted on Jul 12, 2010
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
mishrajk21
  • 202 Answers
SOURCE: HP color laser jet printer is displaying error
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
Posted on Aug 10, 2010
Problema con mi impresora codigo u2
Codigo de estado U2 / Sub Codigo 01 AVERIA DE LA MEMORIA
La PWB principal detectó una avería de la memoria
Codigo de estado U2 / Sub Codigo 02 AVERIA DE LA MEMORIA
La PWB (Placa de circuito impresa) principal detectó un error de acceso
Procedimiento para ambos casos
Realice el procedimiento de anulacion del codigo de estado U2:
  • Introduzca el código de diagnóstico 16.
  • Pulse Impresión.
Si todavia existe el problema , substituya la PWB principal.
Aug 20, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
Tengo una cannon power shot sd600 digital elph, en ella tengo 15 fotos y dos videos de 2 minutos cada uno la memoria es de 500 mb, pero el display dice memoria llena y no me deja sacar fotos ni capturar...
¡Hola!
Bienvenido a Fixya. Posible que sus videos y fotos se guardan en su memoria interna no en la tarjeta SD / tarjeta de memoria. S?lo tienes que seleccionar la tarjeta de memoria de dolor o guarda sus im?genes.
Gracias por usar ou Fixya,
seancarlisle
May 13, 2011 | Canon PowerShot SD600 Digital Camera
Al encender mi camara Nikon S80 me aparece que la tarjeta esta protegida para escritura como lo puedo quitar
¿Por qu? mi c?mara de decir "tarjeta bloqueada" o "protegido contra escritura"?
Los conceptos b?sicos. De la misma manera que las grabaciones en casetes de audio y cintas de VHS pueden ser protegidos por la ruptura de la ficha poco en la esquina posterior, el material en una tarjeta de memoria se pueden proteger contra la que se sobrescriban. En lugar de una ficha para romper, protecci?n de escritura se realiza mediante un control deslizante peque?a en el borde de la tarjeta (frente a la esquina cortada). Antes de que la c?mara tomar? im?genes, es necesario que este control en la tarjeta cuenta con un micro en la c?mara, que s?lo lo har? si no es en la posici?n de "bloqueo". El control deslizante en realidad no hace nada dentro de la tarjeta, por lo que yo no lo llamo un "interruptor" a pesar de que parece como tal. Su ?nico prop?sito es que sea detectado por el micro en la ranura de la c?mara, y es la c?mara que se encarga de la protecci?n de escritura, no la tarjeta.
Diagn?stico. Obviamente lo primero que debe hacer es comprobar que el regulador no est? en la posici?n de bloqueo. Si la c?mara te da este error en la posici?n de desbloqueo, esto significa que el regulador no ha podido hacer funcionar el micro, o que el propio micro est? defectuoso, o tal vez que hay alg?n error de sistema de archivos con la tarjeta. Para diganose el problema, ser?a muy ?til si se pudiera tratar de dos o m?s tarjetas de memoria diferente en la c?mara y ver si s?lo uno, o todos ellos presentan el problema.
Si s?lo uno presenta la tarjeta de memoria del problema: En este caso, es claramente algo que ver con la tarjeta de memoria. Es el regulador desgastados, doblados o que faltan? Una barra de desplazamiento que faltan de protecci?n contra escritura de la tarjeta de la misma manera que el deslizamiento a la posici?n de "bloqueo" se. Hay otra posibilidad. Recientemente he descubierto que algunas c?maras que utilizan tarjetas xD-Picture Card tambi?n dan este error a pesar de que esas cartas no tienen ni siquiera deslizadores de bloqueo! Adem?s, algunos usuarios han informado de la fijaci?n de este error a formatear la tarjeta. Por lo tanto, creo que tambi?n es posible que el error puede ser fijado por cambio de formato. Antes de hacerlo, aseg?rese de que usted ha copiado todo lo que quieras de la tarjeta y luego utilizar "formato" de la c?mara funci?n para formatear la tarjeta. Te aconsejo utilizar la c?mara durante la funci?n de formato porque as? se garantiza el sistema de archivos correcto. Si usted utiliza su computadora para dar formato, usted puede f?cilmente obtener el equivocado. Sin embargo, si es necesario hacerlo de esta manera, ver qu? sistema de archivos est? actualmente en uso en el disco antes de empezar. Vaya a "Mi PC" y haga clic derecho en la unidad que es la tarjeta de memoria, y seleccione "Propiedades". Ejemplos de sistemas de archivos son "FAT" (probablemente FAT16), "FAT32" y NTFS, para asegurarse de que su formato se realiza correctamente, asegurarse de que usa el sistema de archivos igual que antes.
Si alg?n trabajo tarjetas de memoria, y otros no, o las mismas cartas de trabajo, pero a veces s?lo a veces: El control deslizante es muy peque?o, as? que es posible que el n?mero de personas que informar de este error se debe a la falta de precisi?n en los tama?os de fabricaci?n. Debe ser dif?cil hacer un micro que puede sentir una cosa tan peque?a. ¿Tiene una mejor marca de trabajo de la tarjeta? ¿Puedes soportar quedarse simplemente las mejores marcas, o los que trabajan m?s fiable? Como remedio de ?ltima instancia, podr?a intentar envolver una peque?a tira de cinta adhesiva sobre el control deslizante para aumentar su espesor, pero creo que esta es una soluci?n de riesgo. Hay un riesgo de que la cinta saldr? en la ranura y causar a?n m?s problemas, o que la cinta ser? tan espesa que la tarjeta de atasco en la ranura y que tendr? problemas para sacarlo.
Si todas sus tarjetas de memoria se comportan de la misma manera: En este caso, es claramente algo que ver con la c?mara. Podr?a ser que el micro se rompe, o hay alg?n error de software. Aunque es menos probable, vamos a cubrir el error de software de primera; por favor, encontrar la funci?n del "restablecimiento del sistema 'en el men? de configuraci?n y uso para todo claro. ¿Es bueno? Si no, pruebe la soluci?n de cinta adhesiva en el ?ltimo p?rrafo en la esperanza de que se trata de un tama?o o el problema en forma con el funcionamiento de la micro, pero si eso no estamos fuera de las opciones en realidad, m?s all? de la reparaci?n de dicho micro.
Apr 22, 2011 | Nikon COOLPIX S8000 Digital Camera
La marca de la camara es nikon, y me dice que tarjeta memo tiene proteccion escritura, pero nose que es eso...
Verificar el cierre de tarjetas SD Regulador y aseg?rese de que est? configurado para permitir que escribir en la tarjeta. Las tarjetas SD y SDHC tiene un interruptor deslizante a lo largo de un borde. La posici?n extrema de los contactos mantenga la tarjeta, protegi?ndola de los escribe. La posici?n m?s cercana de los contactos desbloquea la tarjeta. Si el interruptor se encuentra ya en la posici?n adecuada, que se deslice completamente hacia otro lado y luego de vuelta otra vez.
Las posibles causas de mensajes de error anteriores
In case of "memory card error" and "card locked" it may due to read/write operation or deep scratch over metallic part of the memory card. En el caso de "error en la tarjeta de memoria" y "tarjeta bloqueada" es debido puede leer / escribir la operaci?n o rasgu?o profundo sobre la parte met?lica de la tarjeta de memoria. Additionally, abnormal insertion/removal of the card, unnecessary camera on & off, virus hit, etc. Including these more other reason may also cause for "memory card error" and "card locked" while the card becomes inaccessible. Adem?s, la inserci?n anormal o eliminaci?n de la tarjeta, la c?mara innecesarias y apagar, golpe? virus, etc La inclusi?n de estas razones varios de los dem?s tambi?n pueden causar por "error en la tarjeta de memoria" y "tarjeta bloqueada", mientras que la tarjeta se convierte en inaccesible.
Suerte.
Apr 03, 2011 | Cameras
Quero saber como dismontar uma memoria ram
desconecta la notebook de la corriente electrica pon la notebook con la pantalla hacia abajo y localiza la ranura de memoria vas a necesitar un desarmada para quitar la tapa una vez que quites la tapa veras la memoria sugeta por 2 laminas separalas con cuidado para liberarla
para inserta una memoria nueva la colocas en angulo presionas con cuidado hasta que las laminas la sugeten de nuevo
Mar 28, 2011 | Dell Inspiron E1505 Notebook
Jul 06, 2010 | HP Laserjet CM2320nf All-In-One Color...
QUE TIPO DE MEMORIA NECESITA PARA TRABAJAR OK
Necesito nombre del fabricador, modelo y mas informacion de los sintomas en detalle... Entonces lo damos sugerencia... Gracias que se ha considerado de neustro servicio... Contactenos con su informacion. Es la manera de como nos clasifican a nuestra habilidad...
Mi nombre es Constantino (arzconst)
May 28, 2009 | Computers & Internet
Me dice un menseje fat error error! reformat external media whith sigma tel formatter
Esto sinifica que el disco duro (una memoria 'Solid State' de un giga) dentro de el lector esta estropeado.
Quando pasa esto se sulen perder todos los datos dentro del mp3.
Intente conectar el mp3 con una ordenadora. en la computadora localize el disco esterior del MP3. Pinche el boton derecho del raton en cima de la icona del disco USB y eliga 'format' desde el menu.
Si format no funziona el suporte de memoria esta estropeado y necesitera un nuevo Mp3 player.
Suerte con su problema.
G.
Apr 15, 2009 | iLO MP3 Player
SER? LA BIOS O EL HHDD MUY GRANDE??
NO NECESITAS ACTUALISAR EL BIOS,ESTE TABLERO MADRE PUEDE LEER EL DISCO DURO.
LO QUE NECESITAS HACER ES CREAR UNA PARTICION DE 137GB O MENOS AL PRINCIPIO DE INSTALAR WINDOWS.
LUEGO PODRAS CREAR OTRA PARTICION DESPUES DE INSTALAR WINDOWS.
CLICK DERECHO EN "MY COMPUTER ICON"/MANAGE/DISK MANAGEMENT,Y SIGUE LAS INSTRUCCIONES.BUENA SUERTE
Jun 19, 2008 | MSI KT600 400FSB (KT6DELTALSR) Motherboard
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
593 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
