Question about Canon PowerShot A3000 IS Digital Camera
How to connect my canon powershot A3000 to macbook air
I want to download photos fr my canon camera powershot A3000 to macbook air
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Posted on Sep 23, 2014
MrsJGreen
  • 130 Answers
SOURCE: Canon PowerShot SX100 is : Need
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
Posted on May 30, 2008
  • 52 Answers
SOURCE: Canon Powershot G3
Actually, you don't need software for an USB cable too. If you have Windows XP, it sees your camera right away and would ask you what to do with that device.
Posted on Feb 09, 2009
  • 38 Answers
SOURCE: MacBook Pro won't recognize canon powershot SD400
Hello. You need to probably reinstall the drivers. but first you have to remove the drivers that are all ready installed. first unplug your usb cord. then to remove the drivers allready installed,, on your computer, press start, then when the box open's up, then right click on computer. another box will open up. then left click at the bottom of that box on properties. another box will open up, then click on device manager. after you click on device manager another box will open up with all your devices. look for the previous camera you had installed. it might be under imaging devices. once you locate that, then right click on it. then choose uninstall. Make sure you have your new software loaded in your cd/dvd rom drive. after it is done uninstalling, just restart your computer. at the bottom right of your screen, it should say, found new device, it will ask you from where do you want to load the new drivers for it. click on the drive that contains the software. it then will load your new drivers up. It then should communicate with your camera. Hope this helps. Ron
Posted on Sep 08, 2009
richard191
  • 691 Answers
SOURCE: Canon Powershot s60 photos have pink tint
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 29, 2009
  • 11967 Answers
SOURCE: Canon Powershot S2 IS is not recognized on my iMac
Simple fix...use a separate card reader to download to a folder you create on your desktop. Once there, you can move them to iphoto.
Posted on Jan 05, 2010
Canon Power Shot A3000IS new Driver
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 21, 2013 | Canon PowerShot A3000 IS Digital Camera
How do I upload photos from a Canon PowerShot A95 digital camera to a 2009 Apple MacBook via USB?
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Jan 06, 2013 | Cameras
How can i upload photos from a canon powershot A3000 IS
You can connect it to a computer via USB and install the necessary drivers/programs or you can take the SD card out of the camera and put it into a card reader which connects via USB and get the photos off that way.
May 12, 2011 | Canon PowerShot A3000 IS Digital Camera
Problems transferring photos from camera to macbook
Use a card reader to download to a folder you create on your desktop. 001cff2.jpg
Nov 01, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
"failed to initialize" camerawindow-downloading images to macbook
Do what the pros do...use a card reader to download to a folder you create on your desktop.
Feb 20, 2010 | Canon PowerShot A470 Digital Camera
Canon PowerShot SD850 photos won't open on MacBook
ur memory card contain virus format ur card and the recover it byusing data recovery software
Jun 17, 2009 | Canon PowerShot SD850 IS Digital Camera
MacBook is not recognizing my Canon G6
Sep 20, 2008 | Canon PowerShot G6 Digital Camera
Open Questions:
See all Canon PowerShot A3000 IS Digital Camera Questions
Canon PowerShot A3000 IS Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
