Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Frigidaire Model FTF21400ES0 Will not sta...
By gracieflower on Jan 12, 2009
I have a front loading model FTF21400ES0 Frigidaire washing machine. My mom used it a few times when visiting. She said several things went wrong (mom has alzhemiers) so she just told me about the second thing today. First she said it was off balance and would stop but she just kept pushing the buttons for it to start. Today she said she thinks the door wouldn't close so she kept on trying to shut it then it did. When I first went to check it when it stopped working. It was up on the metal track the closet doors go on. So I definitely know it was off balance. All the lights will change to the right sequence for all washes. It just blinks and beeps and will not start. I was told it probably was the door lock. I have replaced that and nope it's not that. I really have no money to waste so I am hoping someone could figure this out for me.
I got the tech data sheet went through all the reset stuff but it doesn't respond with any set amount of beeps or flashed to get a error code.
This isn't a digital so no error code. I was planning on replacing the
front load washer control board but am afraid this isn't the problem. I can get a model # FTF2140ES1 cheap enough to try. Is there any way I can tell if maybe when she ran it off balance if broke something. Any help would greatly be appreciated.
Comments:
Jan 12, 2009
- Sorry but I wasn't clear on the model FTF2140ES1. It is a replacement washer control board panel for that model number it is not exactly the same model number as mine. Will that part work, if needed?
Thanks
Jackie
Jan 12, 2009
- No that comment is not acceptable. I would like a the best answer to this since I paid for a solution.
Jan 12, 2009
- Please read ...The washer is not running at all. The lid or door lock or switch has been replaced completely.
Jan 12, 2009
- Washer has power.
Solution #1
posted on Jan 12, 2009
Not Rated)
WebDoc666
Rank: Wiz
Rating: 85%, 310 votes
best solusion is provided by manufaturer online
Comments:
Jan 12, 2009
- ok i try to run the online database for answer
Was this helpful?
Yes
No
Solution #2
Not Rated)
findmeifucan
Rank: Wiz
Rating: 81%, 290 votes
The control board will store error codes in memory. If you can get this unit in a test mode, you will be able to retrieve those error codes. As you hold in both the start & pause/cancel together the error code will be displayed.
You will need to count the flashing lights to read the error code. As you hold in the start & pause/cancel pads together, count how many times the row of lights flash on the far right hand side. This is the first digit. Now, as your still holding in the start & pause/cancel pads count how many times the start light flashes, this will be the second digit of the error code. Take note; all the lights flash at the same time so be sure to take separate readings
Without knowing correct Error code it is useless to waste money in replacing control board . You need to get the error code to diagnosis the problem correctly .
Was this helpful?
Yes
No
Solution #3
Not Rated)
technodeal
Rank: Wiz
Rating: 71%, 53 votes
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
?????????????? If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
for more details just click the following link and follow the instructions
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
Was this helpful?
Yes
No
Solution #4
Not Rated)
taran_2005
Rank: Guru
Rating: 88%, 1082 votes
Refer to the link :)
http://fixitnow.com/wp/2008/05/04/replacing-the-door-latch-assembly-in-a-kenmore-frigidaire-front-loading-washing-machine/
Thanks.
( Copy and paste link in adrress browser )
Comments:
Jan 12, 2009
- Yes that wld work :)
Thanks.
Jan 12, 2009
- When you put it in a cancel/drain cycle, does it pump the water out?
Thanks.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
makes a knocking sound on wash aggitation but not when spinning
Answer
machine keeps flashing door with 1 minute to go on wash cycle and clothes are out of. Cycle appears... (More)
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , IL
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
