Question about Precor 956 Remanufactured Treadmill
I have a 2005 Precor 9.27 that I bought used with only 500 miles on it. This is my first tredmill and I feel it silpping at 5 mph. How do I tighten walking belt? The alignment bolt is at rught rear,so
How to tighten walking belt Precor 2005 ,9.27?
  • Precor Master
  • 914 Answers
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Posted on Oct 31, 2014
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: I have a 2006 Precor
Kindly provide few more details :-
1. If you run it at a lower speed, have you ever noticed an issue with the machine?
2. Is it an intermittent or eveytime you increase the speed to above 5 mph, it would stop?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
  • 95 Answers
SOURCE: Where can I buy a replacement walking belt for a
FitnessRepairParts.com has a walking belt for Precor 9.21 treadmill (it says it is used on four different versions of the 9.21... make sure your specific model number is listed)
Posted on Feb 21, 2011
Proform tredmill---stops after a couple of steps--will start back up after getting off---motor control board?
Inspect the walking board and belt first.Feel the tecture at the outer edge of the belt, then feel the center. If it feel fuzzy, the walking belt is worn.
Check the walking board for damage, deep scratches, excessive friction will cause an over current shutdown of the controller.
If the walking belt and board are good, lubricate the walking board and belt and try again.
Does the motor spark allot when running?? This will also cause over current.
Have you tightened the belt (too tight??)
After covering these suggestions, if the same problem is apparent, change the motor controller..
Dec 16, 2010 | Proform 755cs Treadmill Motor Control...
Carbs sputtering and misfireing on Shadow Spirit VT750 2005
An engine never misfires due to these things. It is always because of maladjustment of the timing at the CB points. Check the timing and set it right.
Apr 06, 2010 | 2005 Honda VT 750 Shadow Aero
Just re did motor what is my break in cycle?
500 Miles stay below red line, below 65 mph. 500 miles change oil and filter ck the drain plug for shavings larger than a pin head,
ck plugs. ck valves if solid. or if you cammed it up. Ride like normal.
Jul 14, 2009 | 2005 Buell Lightning XB12S
2004 GMC sierra 5.3 eng 1500 transmission shutter 40-55 mph
I too have that problem. I own a 2005 GMC Yukon. Shutters between 40 + 55 mph. I thought for sure the stumble I felt was a plug or coil pack because it only does it under a load. With A/C on the whole truck shakes! But it wasnt the plugs or coil packs. Answers anyone?
May 21, 2009 | 2004 GMC Sierra
2005 Jeep Laredo stuck in 4x4 low
you have to run at 1-3 mph speed, to remove it from low
Dec 26, 2008 | 2005 Jeep Grand Cherokee
What are the 5 holes on our buick 2005 lacrosse dip stick mean ?
Even with a new car,unless it burns more than a quart in 500 miles dealers will not do anything for you under warranty. So yes experts consider it normal.
Dec 14, 2008 | 2005 Buick LaCrosse
Precor 956 Remanufactured Treadmill Logo
168 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
