Question about HP 530 Notebook PC
    Problem Solver:
  • 13 Answers
I understand your concern and try to perform this step. I think that you are using HP laptop.Try to check in the device manager if u have the driver or not. If u dnt have the driver try to reinstall it from recovery manager and if that doesnt work try to update it from If still no sound, check in the BIOS by tapping F10 key and try to hit the letter keys and make sure if u can hear the sound. If you dont hear the sound, contact the technical support of HP. If you still have warranty on the laptop they will take in for repair and if not contact the store where you bought the laptop.
Thanks and Regards
Posted on Jan 12, 2009
  • 340 Answers
not to worry, You can find your audio driver HERE: while you are at it, maybe there is a driver or two you could use here as well. - select your operating system and you are ready to roll. plz let me know if there is anything else I can do for you.
regards /Teis
  • Teis Thomsen
    Teis Thomsen Jan 14, 2009
    Back again, just wanted to know if the help you recived "FixYa"?
My computer system is having no sound at all after it was formatted. it is using Windows XP
right click my computer in the desktop click properties then hardware device manager expand sound audio & video controller you will see your sound driver if the driver is marked with yellow question mark reload the sound device driver and restart your system if there is no yellow question mark click start settings control panel double click sound and audio device in device volume move the slider to full and leave the mute unmarked and click OK
Dec 08, 2010 | HP (400745-001) Sound Card
I formatted my laptop with WIN XP. i have to format due to Virus problems. by the time i have done formatting,i have aproblem with my audio device, whenever i play a movie, i have the video but their is...
You just download the right driver for your OS,
Navigate to the laptop manufacturer site and specify the right model number or part number and download the right audio drivers n install it n restart ur machine...
you will confirm the right driver installed for your pc by hearing the logon sound...
Thank you...
Sep 18, 2010 | Microsoft Windows XP Professional SP3 Full...
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
Select [Audio Output Settings].
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Audio device is not working in my laptop
You have to reinstall the audio driver when you format the OS. that is the reason for your OS not detecting the audio device. You will have your driver;s CD with you which you would have got when you bought the laptop.
Jun 03, 2009 | Acer Aspire 1642ZWLMi Notebook
Try getting drivers for the divices that are not working Most drivers I get are on the web site but you need to register and it is free
Jan 22, 2009 | HP Compaq dc5000 PC Desktop
No sound
Download Microsoft UAA drivers for your O/S
Uninstall any sound drivers installed or part installed through device manager.
Install UAA drivers and reboot
when rebooted go to device manager right click sound driver and update will go on net and find and install drivers
Olease give me a Fixya for this solution If done properly will work
Nov 22, 2008 | Compaq Audio card Sound Card
No sound
my computer does not have have,it was recently formatted and since then there is no sound.can you plz help me out...where can i download the sound device form?
Problem of Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
Sep 11, 2008 | Computers & Internet
Sound not coming out
insatall the audio driver, check the device mannager and see if the system detects any audio device if not install the audio driver
Jul 12, 2008 | Computers & Internet
HP 530 Notebook PC Logo
99 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
