Fisher paykel wh60f60w1 Cleaning under door seal. Very grimey.
Clothes spotted with grime
fanny
  • 146 Answers
SOURCE: Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
fanny
  • 146 Answers
SOURCE: fisher paykel washer
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
  • 30 Answers
SOURCE: fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Posted on Sep 04, 2008
SOURCE: hotpoint wma40 door seal
You may also have a black well. If you are not using city water wells often have to be bleached out. Have your water tested.
Posted on Mar 20, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
Fisher and Paykel washing machine model WL80T65D leaking water on filling
were is the leak if leaking at door a new door seal check no clothing trapped in door if you run your finger over loose rubber part of seal at bottom and your finger goes through the seal is perished new door seal i am afraid
Dec 10, 2016 | Fisher and Paykel Washing Machines
Fisher paykel troubleshooting
place your hands on the drum and push it backwards . the door will open when it comes around .
Jul 19, 2014 | Fisher and Paykel DEGX2 Dryer
Model de08-us1
-The seal is shrink so every gap is over size.
-The only thing will eliminate this problem, replace new seal.
Good Luck
Mai
Dec 19, 2013 | Fisher and Paykel DEGX1 Electric Dryer
My fisher/paykel dishwasher does not complete a cycle. it begins to wash and then acts like it in pause mode
It is possible the delayed start option has been set by mistake.
The way to cancel that would be to press the power button off and then on.
However, I am assuming this problem is with only one of the two drawers.
But I am not sure how much of the wash cycle is done before it goes to pause, eg. do you hear the water flowing in, do you hear the washer arm moving and throwing water around?
If it does not get to the stage of water coming in but you do hear some sounds as soon as the start button is pressed then it is likely the door seal is not setting properly which causes the dishwasher to stop.
Anything you see on the display or lights (if no LCD display)? Trying cleaning the door seal with a clean damp cloth. If problem still there then you need to get the door seal serviced. It is slightly sophisticated part with seal and two motors which require some expertise to replace.
Happy to guide you if door seal replacement is needed. Post me a comment on what you find.
Jul 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Black spots and smears on clothes from DRYER (not washing machine
Sounds as if your going for a spin. Not really here is where the problem could be. 1 the bearing on the mchine is going bad. Since the bearing is sealed with its own lubrication the seal has blown seeping the lubrication into the machine one the temp is right to cause the oil to flow. How is this possible you ask? it is possibly flowing down the drum as the drum rotates and entering the dryer from the front of the drum. I would remove the back of the dryer and inspect the area and if all is right with the stars you may not have to take that spin
Good Luck
Dave
Jan 12, 2010 | Fisher and Paykel DEGX2 Dryer
Bottom unit does not always seal and causes water to collect in bottom pan which throw unit into f1 status. Sometimes it stays sealed and is difficult to pull drawer out. Is there a way to reset the unit...
These dishwashers are very sensitive to grime collecting around the drawer edges. Try cleaning with a damp cloth by rubbing along the top edges and the sides where the drawer door sits flush with the body.
Also trun off power at the mains and then turn back on after a short wait.
Oct 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I clean the machine?
Sounds like soap scum build-up. Try running it through a cycle with a cupful of vinegar added. Old-wives method, but I have hard-water, and it works often.
Sep 20, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel top loading washer
This is not grease this is a build up of poweder in the machine on the outer bowl, this will also happen if you use too much fabric softner. :)
Sep 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
