Question about Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594
My snow thrower wont start
My snowthrower is a craftsman 2 cycle 3h.p i clean everytyhing in the motor I even changed the gas line (rubber tube) to make sure nothing was stock in the line. Everything is clean but the snow thrower dont start even with the electric cord.
  • 10,865 Answers
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Posted on Jan 23, 2009
What snowthrower will fit myyth2348 and can a craftmsman snowthrower fit
Yes a craftsman snow thrower can fit, take your model number to sears and they will sell you the correct blower.
Oct 07, 2015 | Husqvarna Garden
Craftsman 18" chain saw 42cc. Starts and runs fine. Will not idle after running for a while. Will not restart when hot. Will start after the saw cools down.
I had a 2 cycle snow thrower that acted similarly. It needed a new diaphragm. When they get old they act up. I could never see a physical difference between the good and bad one but the new one fixed it. It's a flat rubber part that is in the carburetor. Call Sears parts or visit them on-line to get a parts breakdown of the carb.
Feb 22, 2015 | Craftsman Garden
Snow thrower not starting
Two ways to find out:
1.
2.elctric
start with elctric, take the plug cable out and see if have
https://www.youtube.com/watch?v=mUOmsGiirTU
if you have spark go to fuel :
change the old fuel to a fresh one.
https://www.youtube.com/watch?v=RfzzTilqwo0
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Where is the auger sheer bolt
Figure 9 on Page 11 of the manual (linked below) shows the location of the auger shear pins. Do NOT substitute bolts for shear pins!
http://www.searspartsdirect.com/partsdirect/user-manuals/8227/536881800-Craftsman-Parts-SNOWTHROWER,+GAS-manual?pathRender=fromManualTabPage
Feb 11, 2013 | Craftsman Sears Snow Thrower Manual Model...
Engine on 30"Craftsman 2009 snow thrower won't prime. Primer button and connecting tube look good. Primer button won't send gas to the carb.
the priming bubble can look totally perfect, but all it takes is a pin hole and right around the retaining ring is hard to spot a crack and you should also check fuel lines in tank
Jan 07, 2013 | managemylife.com
I have a Craftsman 22" Auger type snow thrower with electric start thatwill not start. It had gas in it from last winter. I primed it , I set the choke to full, gas open all the way and, at first, it
if you are using ethanol the check the gas lines for a plug because the ethanol leaves a residue behind that can plug your gas line.
Dec 29, 2012 | Garden
How to remove bent augers from craftsman 27 inch snow thrower. model #944.528393
There is no repair manual for Craftsman snowthrowers including the Husqvarna built ones like yours. Sears trains their techs to repair these, but not the general public.
Here is the operators manual. It includes detail parts listings so you should be able to go off them to tear the unit apart.
http://www.managemylife.com/mmh/owner_manuals/25209/CRAFTSMAN-Snowthrower-Gas-L0909438?brand_name_search=craftsman+52839
I suggest you split the snowthrower from the power unit and put it on a workbench at a convieninet height for you to work from.
On page 22 of the manual is a parts breakdown of the impeller/blower area. Use this to tear your unit apart.
Feel free to ask anymore questions.
Dec 31, 2010 | Garden
Snowthrower. Won't even fire. Can I just clean carburetor?
See my tip on diagnosing small engines. It works for 2-stroke or 4-stroke engines.
It is best not to use starter fluid. Aerosol carb cleaner is what I use.
Jan 02, 2010 | Toro Lawn Mower With Toro Power Tools
Can't get snow thrower to start
Does it have spark ??? I would check that first, and IF it does maybe add a tablespoon of gas down the sparkplug hole then try it..
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594 Logo
308 people viewed this question
Top Mowtownusa Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Mowtownusa Electrical Supply Expert? Answer questions, earn points and help others
