Question about Nikon Coolpix L26 Compact
Coolpix L26 won't turn on or power up
No memory card, took one pic and never turned back on
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
  • 188 Answers
SOURCE: Nikon CoolPix S5. Red flashing hand. Camera/Lens on/open.
If the shutter is stucked there is no external way to release it Have to show it at camera shop
Posted on Apr 03, 2009
SOURCE: memory card will not stay down in a nikon coolpix s210
Hi, I have exactly the same problem. However, instead of getting a new body with a broken screen and exchanging my screen (One of the only ways round it) I thought I'd try something.
I folded a piece of paper (Quite a small piece) and put in on top of the card when it is popped. I then just closed the battery/card cover and it stayed in place. This is a cheap way of fixing it, it's now been fine for a while, it's a bit of a shoddy fix but it's better than paying nikon £50 to get it fixed.
It takes a couple of trys, getting the paper the right size was a little bit of a pain but it now works fine.
Good luck,
J
Posted on Jun 16, 2009
Ranglo
  • 1194 Answers
SOURCE: My Nikon Coolpix S8000 will
Make sure you insert memory card correctly, when it is fitted into the memory card terminal it give clicking sound. Second thing you can check battery, Direction of your battery might be wrong (+,_), Check out and put it again. Load new or fully charged battery. Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
Else your camera need to be repaired.
Thanks...!!
Rating the solution is highly appreciated.
Posted on Sep 12, 2010
  • 304 Answers
SOURCE: When I connect the Coolpix S3000 to the computer
I've had some S3000's become gimmicy when connecting to a computer. The easiest way I've found to get photos off of the camera is to use a card reader connected to your computers USB.
Posted on May 11, 2011
Why is my nikon coolpix L26 not uploading my pictures
First, use the review function to make sure your camera actually took the pictures. Assuming it did, I would remove the SD memory card from the camera and use a card reader to transfer the pictures to your computer. If your computer does not have an SD memory reader, many USB readers are available for under $20. They are USB devices and once they are attached to your computer and you insert the SD card, the computer will act as if the SD card is another external hard drive. You will be able to transfer your photo files from the SC card to a file on your hard drive via copy and paste or drag and drop. Although you can erase your card when you are done by deleting the files, it is better to put the card back in your camera and use the format function found in you camera's menus.
Jun 19, 2014 | Nikon Coolpix L26 Compact
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
I have an Nikon Coolpix L26 digital camera, and I want to know how to delete my 500+ pics on the SD card after after importing them onto my Mac using iPhoto. These pictures have been on the card for a long...
Use the Format command in the Setup menu. See "Format Memory/Format Card" in the manual (page 54 in my copy). If you need a manual you may download a copy from here.
Mar 24, 2013 | Nikon COOLPIX Cameras
How do I revert the image numbers back to 001 when I've deleted all photos off the memory card. Nikon L26 Coolpix
I do not have an L26, but on Nikon SLR's there is a menu item that allows you to reset the counter. The L26 may have the same feature since it is rather basic. Have you looked in the manual that came with your camera?
Jun 09, 2012 | Nikon Coolpix L26 16 Megapixel Digital...
I took the memory card out of my coolpix 4600 and put it into a vivitar camera when i inserted the memory card back into my coolpix cannot get the camera to work or turn off
Did you take pictures with the vivitar camera and saved it on the same memory card? If so, that might be the problem. Delete those files taken by vivitar (copy them to your computer if it is important before deleting) then try the memory card again on your coolpix.
Jun 16, 2011 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Jun 13, 2011 | Nikon Coolpix S3000 Digital Camera
My l110 has transferred fine until now. now when i plug it in, nothing happens. i have tried using the picture wizard and nothing happens. a card reader won't help because the pics on stored in the...
You need to get a memory card. Then, go into the menu and find "copy" which will give you the option to copy the internal memory to the card. Then, use the card reader to download from the card.
Jun 02, 2011 | Nikon Coolpix L110 Digital Camera
I downloaded my pics off my memory card to my laptop now the memory card is reading when i turn on my camera memory card is write protected what does that mean? i have a nikon coolpix s60. when the memory...
Look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 22, 2010 | Nikon COOLPIX S60 Digital Camera
Nikon Coolpix L26 Compact Logo
556 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
