Question about Maytag Refrigerators
Maytag refrigerator mf12266aeu control panel is flashing and popping and door to ice dispenser is opening and closing constantly
Control panel appears to have a short in it.
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
SOURCE: Maytag MFI2568AEB- icemaker flapper keeps
Replace main control board known as the hv board part number 12920710 Ive replaced many the reprogramming code number is on the model number sticker the instructions for reprogramming are in the Tech Sheet located under fridge behind front grill rh side stuck to the top of the bottom in plastic bag new board will not work without reprograming Can you solder? replace the 2 680 microfarad caps located on the board located lwr center next to the china sticker they are side by side and the tops of these caps apear to be bubbling out. Mouser.com mouser part number 647-upw1v681mhd caps are less than a $1 a peice and new board $180
Posted on Apr 03, 2009
SOURCE: Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light show last night. Followed instructions above to disable it, which temporarily solved the problem. Was on the phone with Maytag (Whirlpool?) this AM, and their initial response was that they wouldn't cover anything since we are out of warranty. I had to be extremely firm with my expectation that all parts and labor would be covered. Sent the rep back to her supervisor several times until they agreed to cover both. If you find yourself in a similar situation, don't give up until everything is covered. This is a design issue that should NOT be impacted by an expired warranty!
Posted on Apr 15, 2010
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
SOURCE: what does it mean when lights on control panel
Ours started the same thing today. Called the 800- Maytag service number. They said it is a "known quality issue" with the controller and scheduled maintenace call. If gone unfixed, the controller will probably eventually fail and the frig will quit working all together. From what the lady said, this will be a free fix even though it's passed the warranty period.<!-- from fixya rte -->
Posted on Aug 15, 2010
I described the problem poorly, I apologize. The freezer and fridge are at the proper temperature (freezer is at 0, fridge at 40). I've checked and the water flow from the wall into the machine is good...
Hello David ,
Their are a few possible reason the ice is not being dispensed,
1) the door switch is bad...the door must be closed for the ice to dispense and perhaps the switch thinks the door is open
2) the switch that is activated when pushing the lever on the dispenser is bad
3) the dispenser motor is bad
4) the control board is bad
GENE
Sep 23, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Why is the ice maker and water dispensing panel on my refrigerator flashing? The Ice door at the dispenser is also opening and closing every three seconds. Water and ice are also not dispensing
I called a repair man to fix this problem - "FixYa" was absolutely useless in this case. Turns out there was a short on the control board and it needed to be replaced.
Dec 02, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Panel flashing, ice door opening and closing constantly
I had the same problem, with this model and it was the high voltage control board located in the rear. Replaced the board and it is working OK. Maytag Part # 12920710 will work on this model and it is 40.00 cheaper than the one it shows when you do a parts search. It will come up 12920709. I checked with Maytag and they said 710 will work..
Sep 23, 2007 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
54 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
