No power getting to tv
After plugging the tv into the wall when you switch the tv on we get a loud crack and a blue flash comes from the back of the tv unit can you please help
  • 140 Answers
You do not say what type of tv you do have but the problem you are getting is from what they call the high voltage tripler, the part in your tv that actually furnishes the high voltage so that you can see a picture. It is not something that unless you are a technician that you can fix. It wil probably cost you like $45 -70 for the part without the labor. Take care and God bless.
Posted on Jan 12, 2009
My tv will no switch on
Can I suggest ....if you have not already done so.....Switch off from the power button. Switch off from wall socket. Leave for a few minutes. Plug in..switch on....Make sure if you have a remote the batteries are OK..renew if you need to.
Jun 29, 2016 | Luxor 19822 COB
The electricity went off when the tv is still on.when it came back the tv does not switch on.when i switch it on it flashes the blue light fast and change to the red on.what could be the problem?
Pull the wall plug and count to 10 and then reconnect. If it doesn't work phone your electric company and tell them you are going to sue them for damaging your television!
Nov 11, 2015 | Televison & Video
My Digihome tv 32913LCDDVD is stuck in standby (blue light flashing) can you help me resolve this problem please
Count the number of flashes occur at one time switch ON. These flashes are called blinking codes; and are fault indications. Form the number of these blinks, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details about these blinking codes, check the site linked here.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Digihome LCD TV
I have flat pannl Vizio 42" ..Watching TV...a loud crack came from TV and set went blank and will not come on...tryied reboot...still unresponsive..
I'm sorry that the TV has produced a loud crack and not turning ON. Please check the following troubleshooting steps and check the operation:
  1. Please make sure that the connections are secure and proper.
  2. Connect the TV to a different wall outlet and check the operation. (Connect it directly without using Surge Protector)
  3. Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
  4. If the issue persists, please open the cover of the TV and check the Power board for any burned fuse.
  5. Use a multi-meter and check whether the Power board is outputting +5V.
  6. Replace the fuses if necessary. Most Vizio TVs using fuse 0185-1302-0073(Part #).
If the issue persists, physical evaluation is required to find the exact issue. You can click hear to locate your nearest service facility to get the TV evaluated.
Thanks for understanding.
Sep 11, 2011 | Vizio 42 in. LCD TV
My TV was working and then all of the sudden the screen went blank and now there is a flashing red light that appears. I tried to turn everything off and back on (the universal solution to everything) but...
There is something confusing the system control of your TV and it should me resetted. To reset it, just switch OFF your TV with its front panel power control switch, and after that, unplug the TV from the wall socket. Wait for about 5 minutes or so, and the plug it and switch It ON. If this does not work for the first time, give some more time to reset, say about an hour or so, and try. OK.
Jan 29, 2011 | Philips 37PFL5332D 37 in. LCD Television
I have a 50PC1DA Power Issue
Hello Junior,
This type of failures is commonly due to defective capacitors in the power supply.
Check the video from the link.. LG 50PC1DA Not powering up clicking sound no picture or sound Diagnosis
Aug 30, 2017 | LG 50PC1DRA 50 in. Plasma Television
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
LC 32D43U power and OPC green light flashing set does not come on
hey i have had the same problem but i unplugged the tv for awhile about a half hour and then plug your tv into a different wall outlet if you can and should work. It worked for me, i had it plugged into a surge protector then i unplugged it from there, let it sit of half hour then plugged into different wall outlet and worked. so try that and see if it works.
Dec 29, 2007 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
