Turn off radio alarm on Grundig M400
SET IT TO TURN ON RADIO, BUT NOW CAN ONLY TURN OFF RADIO WITH "POWER" BUTTON
Noggin
  • 944 Answers
SOURCE: I need to know how to set the radio presets for the Grundig.
If you go to this link; http://www.amazon.com/Grundig-G2000A-AM-Shortwave-Radio/dp/B00000JD4T/ref=pd_bbs_sr_3/104-1966292-9407907?ie=UTF8&s=electronics&qid=1175876962&sr=1-3 This is the same model, and under "product details" you can download the manual. Page 21 of the manual (page 10 of the pdf file) should tell you what you need to know. Hope this helps :)
Posted on Apr 06, 2007
SOURCE: users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Posted on Feb 28, 2008
SOURCE: Grundig yacht boy 400 radio does not work with mains operations
hello i have a grundig mini-300 radio , the volume control is stuck in high range . i have had many problems with this radio , i would love to talk with one of your representives . please call me at 585-313-3188,,thank you ,,,,nicholas ferrara
Posted on Aug 19, 2009
  • 7993 Answers
SOURCE: How can I get a manual for the Grundig G4000A?
Here is the link to eton corp for your manual
Hope it helps.
Posted on Nov 06, 2009
kb8dns
  • 494 Answers
SOURCE: broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
Posted on Feb 14, 2010
How to set alarm
Install batteries. Press and HOLD down alarm button. While holding down alarm button, press hour button until hour is set, then press minute button until your time is set. release alarm button and set time will be saved. Activate alarm function, by selecting band and station, pressing alarm button, and alarm indicator appears and alarm is on. The station will play when alarm time is reached.
Sep 10, 2014 | Grundig Mini 400 AMFMSW Radio
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
How to set presets on nelsonic clock radio nlc 618
To set this alarm first ensure that when you press the Mode button several times the FM/AM radio does not turn on . If the FM or AM radio does turn on or the lcd displays "AU" press the Power button that is next to the Mode button 1 time (pressing the Power button toggles you between 2 settings). You should now be able to press the Mode button at least 3 times without the FM/AM Radio turning on.
Next you press and hold the Alarm 1 or Alarm 2 button and (while continuing to hold down one of the Alarm buttons) press the Hour or Min buttons to set the time of whichever alarm button you are holding down.
When you have the alarm time set you can release the Alarm 1 or Alarm 2 button and press the same button (do not hold the button down this time) to cycle between the types of alarms you can use. You will see the blue circle indicator move between Buzz and Radio when pressing the buttons (Blue circle on left side is for Alarm 1 and blue circle on right side is for Alarm 2). There is a third option as well but I'm not sure what the alarms will do if you set them to it because the blue circle indicator disappears entirely after cycling to Buzz and then Radio.
Hope that helps!
Apr 23, 2014 | Audio Players & Recorders
Screen lock decode
Some Grundig/Eton radios have a button with a key lock symbol.Once the button is pressed it toggles between lock/unlock. In the lock status, the settings (frequency, time, scan, etc.) are disabled. Another function that is disabled is the Power On button. This feature prevent the radio to turn on if the power On button is pressed inadvertently when the radio is in a bag, or a suitcase.
Nov 07, 2013 | Grundig Audio Players & Recorders
I have a Grundig Mini 300 World Band Receiver and the power button has stopped working so I cannot turn the radio on.
Spray some WD-40 on the on/off button and press and release the button multiple times. This will clean the gunk built up on the micro-switch and make a better connection.
Jan 05, 2012 | Grundig Mini 300 AM/FM/SW Radio
I have a Grundig radio S350DL and I cannot switch off the sleep function and therefore the radio automatically switches off after 30 mins. or so . Can you advise? Les. Akers
The Power and Sleep Functions share the same button. If you press the Power/Sleep button repeatedly you see numbers displayed 90, 75 60, ... 01. These are the duration of the sleep functions. If you stop at 60 the radio will work for 60 minutes then turns itself off. This must be a battery saving feature so that a radio will not be on for ever. Suppose the radio has been on for a while (long or short) and you want to turn it off without waiting for the sleep timer. Just press the Power/Sleep button.
Aug 10, 2011 | Grundig S350DLB FM Radio
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
I can't figure out how to set the alarm and make sure that it's set. The instructions with the clock radio are not clear. Also not sure how to turn off the alarm when it buzzes in the morning.....Help!!
Hello Barb,
To set the alarm hold either alarm 1 or alarm 2 buttons down. While holding down the button adjust the hour by pressing the tune+ button. The bottom left of the display there will be a light letting you know if it is pm or am. While still pressing the alarm press tun- to select the minutes. If you want to wake with radio or a buzz keepholding the alarm button down and press the am/fm/aux button. Release the alarm button when done. To select an alarm just press the alarm botton you want once, a light on the right side of the display will turn on. To unselect press the same alarm button once and the light will turn off. To turn the buzzer off in the morning select power/al off button located at the top left of the unit.
Jan 05, 2011 | GPX C389B Clock Radio
Hope it helps.
Sep 09, 2009 | Grundig G4000A FM/AM Radio
247 people viewed this question
 Grubhead
Grubhead
