Maytag MER5775Q Electric Kitchen Range Logo
Anonymous Posted on Dec 07, 2012
Maytag MER 5775 QAW door removal
I need to remove the door to fix the door handle
  • Anonymous Dec 09, 2012
    There are two little tabs at the hinges in the bottom of the door. APPLY WD40. Wait.....Pry the hinges toward the door. They move in a radial fashion an inch or so.Then you may pull the door up and out the tabs toward you
4 Related Answers
jjas
  • Posted on Oct 17, 2007
SOURCE: Maytag electric range door handle (how to replace?)
The above solution is fine, but you don't have to remove the door.  Open the storage drawer for access to the trim screws (3) on the bottom of the door, remove the screws.  Have a helper hold the glass along the bottom. Take the three screws on the top of the door trim out.  Slide out the glass and put in a safe place.  Remove the four screws that hold the handle brackets in place, remove the handle (or tighten if loose). Install the new handle (one screw on each side).  Reinstall all parts in the reverse order of disassembly.  The entire job took less than 30 minutes.
Anonymous
  • 878 Answers
  • Posted on Jan 10, 2008
SOURCE: oven door handle
Lady, you are going to have to take the door apart to get at the handle screws. The whole door will lift off the hinges, place it down on a flat surface and go from there. You can find your manual with instructions at http://www.servicematters.com/maytag_library/docs/16010107.pdf
If that link doesn't work, go to servicematters.com, click on the Maytag section, follow the links, enter your model number and you will find your manual. Make sure to take your time, these can sometimes be a pain. Catriver.
Anonymous
  • 706 Answers
  • Posted on Aug 22, 2008
SOURCE: I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Anonymous
  • Posted on Jan 18, 2009
SOURCE: remove oven door on Maytag MER57 electric oven
The solution was very simple, after wasting 3 days inquiring on the internet, calling dealers, and calling Maytag help. I removed the drawer, laid down on the floor, and saw that there were 3 screws on the bottom of the door holding the glass. I removed those 3 screws (there was also a "slot" screw on each end that I loosened) and walaw! the glass dropped down, I removed it and cleaned it with window cleaner, and replaced it. It shines like a new silver dollar and I am soooooo happy. There are 3 classes and I would have removed the center one because it had a tiny spot on it (on the inside of course) but my husband was nervously standing over me and I didn't want to push anymore buttons, if you know what I mean! Next time I will do that.
Maytag centenial gas dryer replacement handle...have part
It may seem crazy, but you have to remove the dryer door, and then take the door apart to be able to replace the handle! I've tried doing it without taking the door apart, and I only ended up damaging the door and replacement handle!
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
1helpful
Hi Team at Maytag I have been trying to find the Model number online but no luck. mine is a GS2325GEKB and I am trying to solve how to get to the screws that hold the stainless steel door handles on as...
These door handles are held on by clips and are hard to remove at maytag they gave us a plastic card that you slide up under the handle and pull upward on the handle to release it from the door. DO NOT remove the inner door skin!!! the handle slides off and the screws and clip are under the handle.
2answers
I have a Maytag MDB6600AWW that is giving me a fit. It only works when it wants and the door is hard to operate as the handle isn't connected correctly anymore.
It could be your lid switch.
If the door handle is brocken the lid switch is not making contact properly.
Ash
Oct 21, 2009 • Dishwashers
7helpful
Maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
2helpful
2answers
The entire door handle snapped off
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
1helpful
Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
35helpful
10answers
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
