No Internet Access on NeoTV
NeoTV NTV300 on wireless G network was working fine an hour earlier - now it connects to the WAN, but not the internet. Same wireless router works perfectly on several wireless computers and devices - Internet access is fine - just not with NeoTV. On the same TV, my wireless Sony Media Player works perfectly, and streams NetFlix and other internet media perfectly. It is only with the NeoTV. I have 2 of these NTV300 units, and they both have the same problem. Wireless Router settings have not changed.
  • 35 Answers
SOURCE: I can't access my router through the URL.
If your computer is connected to your dlink network you should be able to access.check the ip address on the computer.if correct ip address optimized browser by deleting cookies and temp files.Also try downloading firefox
Posted on Aug 19, 2008
i can't access my router though the url
Posted on Nov 25, 2008
  • 258 Answers
try typing the full url
http://192.168.0.1
Posted on Feb 15, 2009
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
Rajan Solank
  • 62 Answers
SOURCE: computer and wireless router being connected but no internet
To reset the Modem all you have to do is to get a Paper Clip or any object that is like a paper clip then just turn your router to the place where the LAN cables are and just nearby you will see a small button that is abit hidden , so just press that and while pressing it for 5seconds, remove the power cable and plug it back while the clip is still being pressed in the reset button.
Remove that clip from there and you should be able to see that your power light on the router is blinking, wait till it get stable, then all you have to do is login with going to 192.168.1.1 then enter the default username and password which is either admin, admin, or root, password. or root, admin
Then just configure your router again and all shall be well.
THanks.
Hope this helped you.
Posted on May 26, 2009
Wireless internet connection trouble
Your question is vague ? What trouble are you having ?
Are you using WPS (like auto setup Wi FI from Router) or manually where you look for the wi fi name (ssid) and select it and then you pick the encryption WEP or WPA and put in the encyption key . Which may be on the case of the router or you can log into the wi fi router and find out what encryption is being used and what the key is. Have you read the manual page 25 ?
https://www.manualslib.com/manual/669193/Netgear-Ntv300.html?page=25#manual
Feb 13, 2015 | NetGear NeoTV NTV300
How do I get neo tv to work again , bottom of screen says fatal: internal storage failure
Sounds like the internal hard drive has failed. Most places that know how to fix computers should be able to help. I don't know how much your neo is worth, but a new hard drive could cost anywhere from $60 on up.
Dec 22, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
Direct access through LAN cable internet was working fine. whereas while connecting through DLink(Dir 600) pages were not loading correcly. I tried Netgear modem it was working fine. What is the probl
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
Aug 31, 2014 | D-Link Dlink Dir-600 Wireless Router...
Netgear streaming player
Sounds as if it has found an open Wi-Fi connection, but the device it is connecting to doesn't have an internet connection.
Make sure the Netgear player is connecting to your wireless network, and that you have a live connection to the internet.
Aug 30, 2014 | NetGear NeoTV NTV300
My neotv will not let me watch anything
Check to see if there are any physical obstacles that might interfere with your WiFi signal, things like metal wall studs, metal cabinets, etc. if that is the case and you can't move your neoTV setup, you might need to get a WiFi booster. That worked for us.
Jul 25, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
We have a netgear neotv streaming player ntv300. We had it connected to the tv and then it had a message that it needed to be updated, so I checked it to be updated and it started updating for a whil
We had this problem too. It turned out our wi-fi signal was too weak. After we installed a wi-fi signal booster, the netgear update was completed with no further problems.
Mar 10, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Router -> Modem Connectivity: I am fine if I'm hard-wired to the modem but if I connect wirelessly through the router I can't get WAN. I can get the modem page wirelessly. This just started tonight. I...
Have you check your DNS settings within your Wireless Network Adapter TCP/IP properties settings? Or it may be a proxy server or firewall settings wich may block internet access to the internet. Try testing it with your LAN cable first and see if you are able to connect to the internet using that cable from the laptop/pc to the modem. If it works using the network cable then it might be a DNS related issue on your wireless network adapter tcp/ip properties.
Jul 29, 2009 | Belkin (F5D5231-4) Router
Ntl:Home Compatibility
When you say the networking is fine, I assume that you can connect all wireless devices together and access the router menu on IP 192.168.2.2 (refer page 23)
Is it possible that when you connect the router to the modem that both are trying to assign an IP to the other?
My router is set to get it's WAN IP from the modem (it's a d-link though)
refer to the manual on page 28- try setting the WAN/internet setting to dynamic. You should leave the host name blank and not clone the MAC address.
MANUAL
Post back results and I will try to assist further if required
Jul 06, 2008 | Belkin Wireless-N Wireless Router with...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
