Question about Apple PowerBook G4 Mac Notebook
Syncing new address book
We just added a new G4 notebook, via Airport, to our network, but we need to sync our address book:  Can you help us?  Great advice last time.
  • 34 Answers
I had to read your last post to get some idea as to what was going on. This is a solution sort of but you need to ask what yourself what do you mean by sync? Do you want the contents of both address books to be the same but not update when you make a change on one or the other. Or do you want your address books to update each other when you make a change in either one. That is something you have to decide. For the first option you can open your address book from the dock and select all of your contacts. Then you want to go to the file menu and chose export and then chose v card. This option will place a card for each contact in a folder of your choice. This option is the best if you are moving info to a windows pc as well.
The second option is easier but has two choices for you two pick. if you want both of your address books to be the same at all times you need to connect your address book to an in between system. there are two you can choose from, one is mobile me an apple product which does more than just adress book sync but comes with a fee. there is also a site called plaxo.com which also does address book and calendar sync for a mac only.
I hope that helps fix your issue
Posted on Jan 25, 2009
SOURCE:
Transfer books from laptop library to my new tablet
What kind of new tablet do you use? If it's an iPad, you are able to download books to iPad directly. Just launch iTunes on your tablet and go to iTunes Store, then search for the book you need and click Get below the book cover.
transfer-books-from-laptop-library-new-oxaxc0rwhkhzilrwacqreyis-2-0.png When you want to download ebooks to iPad, you are able to sync the books with iTunes. Having the latest version of iTunes installed on computer, you are able to connect your iPad to computer with USB and sync ebooks to computer.
After getting the ebooks in iTunes library, you are able to sync the books to iPad easily. The following guidance will show you how to finish the task.
1. Plug iPad into computer via USB, and iTunes will launch automatically.
2. Click the iPad icon and choose Books category in the left sidebar.
3. Check Sync Books and choose All Books or Selected Books.
4. Click Sync at the right bottom to start syncing books to iPad.
After syncing books to iPad with iTunes, you will get the books in the iBooks app on iPad. Now you have an enjoyment. But note that you should shut down auto sync before you sync books with iTunes. To shut down auto sync of iTunes, you need to go to Edit > Preferences > Devices on iPad, and check "Prevent iPods, iPhones and iPads from syncing automatically".
If you have downloaded or got books from elsewhere, you can add books to iTunes at first, and then sync these ebooks to iPad. To add ebooks from computer to iTunes library, you only need to click File > Add File to Library at the upper left corner of iTunes, and then the ebooks will be added to iTunes Book Library.
Visit this guide for more methods about how to transfer books to iPad tablet. http://www.leawo.org/tutorial/download-ebooks-to-ipad.html
Apr 10, 2016 | Computers & Internet
Transfer my contacts from laptop to iPad?
if you have a cord to plug into your laptop to your ipad. it will walk you thru it.
Oct 08, 2014 | Computers & Internet
Will not connect to internet via airport
Start from scratch. Go back to your main computer and create a USB key and try that way.
Wondering, is your MAc setup for wireless?
Another thought, i had the same issue connecting my Mac to my parents wireless. I used the installation disc and that solved that.
Mar 26, 2009 | Apple iBook G4 Mac Notebook
Ibook g4 freezes and airport problem
have you gone into airport utility?
are you using an airport extreme? if so, reset it.
then delete the current wireless network, and try setting up a new one in airport utility.
Feb 16, 2009 | Apple iBook G4 Mac Notebook
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Wireless Modem don"t connect
well imac G4's don't  have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card  then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
Apr 07, 2008 | Apple iMac G4 Desktop
Address Book Not Synching
If addressbook is presently syncing to Contacts in Outlook, then you will need to reinstall the desktop to alter the conduits. The reinstall should overlay the present version. Just select to alter conduits when requested.
Sep 14, 2005 | Samsung SPH-i500 Handheld
Apple PowerBook G4 Mac Notebook Logo
88 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
