Question about Route 66 GPS
Cannot exe route 66 running wince 5 "engine initialization error code 0x6"
SOURCE: I receive the error message
fatal error occurred, restarting
Posted on Dec 13, 2008
  • 6 Answers
SOURCE: I cant get tomtom or route 66 to run on my pnd windows ce 5.0
router problem
Posted on Jul 04, 2009
jamespcastle
  • 128 Answers
SOURCE: brand new vrgp430wbc nav states route 66 has
press and hold the reset button for 5 seconds on the back of the device.
Posted on Apr 22, 2010
SOURCE: I have an A2265FF all
Meu GPS n
Posted on Aug 29, 2010
angelo_mlc
  • 1035 Answers
SOURCE: Engine initiallzation. Error code 0x6.
Hi. This error is a disk error. Are you trying to install program in your computer. Here's an article for this error message.
Posted on Oct 30, 2010
I got the VR3 gps with back-up camera less than a month ago, the first day it worked perfectly fine, then when I installed the route 66 stuff it started showing me some really long message saying to...
Ok so this happened to my gps after an improper shut down. Here is how I fixed it. Follow each step carefully and make sure your gps is fully charged before beginning.
1st open up the route 66 disk to see files not actually accessing the program. Right click on the disk and tell it to open from my computer. you will see many files one folder will say memoryimage.
2 Then on the gps click on settings and go to backlight setting backlight to the dimmest stetting. Now go into power and tell your gps to never standby.
3 Plug your gps into your computer then turn it on. Windows mobile will come up click on connect without setting up your device. Under file management click on browse contents of your device. You will now see what is actually on your gps. Open NANDFlash.
4 Now select all items except the route66 folder in the memoryimage folder of the disk and move them into the NANDFlash folder of your gps. When it asks how to transfer tell it to replace current folders with the same name. It will then take several hours to transfer.
5 On mine the route 66 exe file would not transfer back into the actual route 66 folder so I created a new folder then transferred the route 66 exe file from the route 66 folder in memoryimage of the disk into my new folder in NANDFlash. Once it is transferred you should be able to click navigation on the gps and have your gps load route 66. Your maps will be locked.
6. I kind of forgot how I did the next step because I cannot get back to where I was because I have already activated my gps. Go into the main menu from inside route 66 and either enter the extras folder or route 66 settings. Somewhere in one of these you will find a place to activate your route 66. It will then give you a website and an id for your gps. Go to the website and enter your gps id and the code from the voucher code card which came with your gps. Once entered on the website you will receive an activation code which you will have to enter into your gps. I recommend you turn off your gps then turn it back on and give it time to find you. You can go into gps status to watch for a signal and once you have a good signal it may take several minutes to locate you. After it has found you it should be working fine.
Aug 06, 2010 | GPS
Brand new vrgp430wbc nav states route 66 has
Feb 19, 2010 | GPS
Createfile failed on INI file
Hi. I had the same problem, and i fixed it by creating a APShell.ini file wich was missing in MyFlashDisk\Shell directory.
In APShell file :
Version=1.0.2.43
Language=23
[Navigation]
Path1=\SDMMC\ROUTE66\R66n8.exe
Path2=\SDMMC\N8\Navigate8UI.exe
Path3=\SDMMC\ROUTE66\R66Navigate8.exe
Caption1=Navigate
Caption2=N8
Caption3=Navigate
ClassName1=
ClassName2=Explore
ClassName3=
Reset=
reset device and it should work.
Mar 30, 2009 | Route 66 MINI Handheld GPS Receiver
I have an A2265FF all in one navigation unit in my ford focus, the SD card had route 66 installed on the card which I updated and since then I have lost the files for loading the navigation, I have...
I can understand your problem, this problem arises with new SD card.
So, please copy Navione folder to memory card root directory, enter the directory, use Notepad to open Loader.ini to edit, enter your correct path, for example: \ Storage Card \ NaviOne \ NaviOne.exe save you, run to enter Loader.exe navigation procedures.
I'm sure it will work out for you. The error message shows similar indication. So, do it and load your route installed. It will work out surely.
With Regards,
Shyny
Apr 22, 2009 | GPS
Route 66 Mobile 8 Windows Mobile - software update creates error
To upgrade, use the website version of Route 66 Sync rather than the version on the disk or the upgrade file from the website, both of which do not work. The website version works in conjunction with Microsoft ActiveSync.
Dec 27, 2008 | Route 66 ROUTE EUROPE 2004 (601184407502)...
Finean.exe error
make sure your SD card is not locked. Attempt to write a file to the card. If you cannot, move the switch on the side of the card. Otherwise, visit www.finean.com.
Oct 30, 2008 | Route 66 Route USA 2004 for Mac
HARDDRIVE FAILED
Get a new V3000 hard drive. They are cheap. That hard drive is corrupt.
Aug 14, 2008 | 3Com NBX® V3000 (3C10600BUS)
I cannot access the user manual
do you know the acdivation code for a Route 66 Mini Regional SAT NAV. Bought from Halfords.
Dec 26, 2007 | Route 66 Mobile 7 GPS Receiver
GPS Logo
Top Route 66 GPS Experts
Are you a Route 66 GPS Expert? Answer questions, earn points and help others
