Question about Canon Office Equipment & Supplies
How to read counter on canon iR2018 - Canon Office Equipment & Supplies
3 Suggested Answers
randula7
  • 78 Answers
SOURCE: System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Posted on Jan 10, 2010
canontech
  • 1219 Answers
SOURCE: canon2018
Send the e-mail, and ill send it to you.
But shortly:
Remove left door on copier.( Remove plastic cover left from the door ( 3 screws ), disconnect the wires if you have duplex, unscrew the screw on black plastic tape, with pliers pull up the metal pin wich acts as upper hinge.)
When you removed the door, from left side beaneth the fixing assy you will see smal black cover with one screw, remove it so that you can disconnect the connector of fixing film assy, from the right side of fixing assy, remove the cover ( that is the cover wich is long and covers the door locking mechanism - two screws ) Disconnect the 3 conectors. Unscrew the scres that holds fixing assy left side and right side.
Pull towards the fixing assy.
Dismantle it how you see it, but you need to remove the green handle, and remove the axis that have on both side plastic pressure realese pins.
Pls. rate
Posted on May 14, 2010
Canon ir2018 error e808 how to clear
To clear the E808 code unplug the machine for about 10 minutes. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. If you have tried to repair this machine, make sure you have not left the connector unplugged.
Jul 30, 2014 | Canon Office Equipment & Supplies
Canon IR2018 service manual.pdf
hello friend, you can find the canon iR2018 service manual in below link:
Canon iR2018 service manual:
http://goo.gl/Ckm4yf
thanks
Oct 31, 2012 | Canon Office Equipment & Supplies
IR2018 output Toner Densiy was light. Why?
Clean the original glass,mirrors and lens in the optical part,and change the PC drumif your total copy counter indicated 40000 copy or more.
Aug 14, 2012 | Canon Office Equipment & Supplies
Canon ir2018 copier error messages E000 and E003
hi that errors indicate there is temperature failure in the fixing unit maybe caused by AC energy fluctuations . . . verify energy supply is correct . try to connect the machine in another Ac outlet. if problem persist maybe the fixing heater is malfunctioning
Jun 14, 2012 | Canon Office Equipment & Supplies
Service Manual for Canon iR 2018
Canon ImageClass iR2018 service manual:
http://goo.gl/6RzVMb
thanks
Apr 03, 2012 | Canon imageCLASS Office Equipment &...
Where do i find the fixing film?of the ir2018 canon printer. what does it look like and how do i replace it? mukopaje@live.com
hi,
please do following
m good with laser printers but when it comes to copiers. ... I have a Canon IR2018 MFD copier. It started giving me the e007 error. I know this has somthing to do with the fixing film. ... Does anyone have a service manual or a technical diagram of a canon ir2018 copier.....that would help alot. ...
www.copytechnet.com/.../canon/41455-canon-ir2018-fixing-film-replacement.html - Cached iR2018 fuser replacement... Repost for mnamono‎ - 7 posts - 27 Oct 2010
IR 2018‎ - 9 posts - 20 Apr 2010
More results from copytechnet.com »
May 30, 2011 | Office Equipment & Supplies
Instructions for ir2018 canon copier how to use
Here is the link for the manual http://files.canon-europe.com/files/soft37766/manual/m_iR2022_iR2018_BGR.ZIP
Feb 28, 2011 | Computers & Internet
Steps to configure Canon IR2018 printer in network using network port of the printer
steps to configure Canon IR2018 printer in network using network port of the printer
Oct 26, 2010 | Canon Office Equipment & Supplies
E805 is Fan failure
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
218 people viewed this question
old marine
old marine
