Question about Canon PowerShot G2 Digital Camera
Noise inside camera
Buzzing noises are constantly emitted by my G2 camera. It is still working but the noise is terribly distracting. Is it autofocusing and how can I make it stop?
  • firefam31 May 23, 2008
    The camera makes a constant noise, even when it's just on and not taking a picture. Kinda of a whirring noise. Doesn't focus well sometimes, has started taking fuzzy pictures. Sometimes it's as if nothing is wrong.
It does have that problem. GLETwhirrrrPFTTtrrr....as the lens extends...Mine does the same thing. I have had it for 4 years now and counting. So Don't worry about it.
Posted on Nov 06, 2007
    Genius:
  • 2,985 Answers
What sort of noise and is it constant?
Posted on Aug 04, 2007
Yamaha YSP 800 Digital Sound Projector constantly emits a low buzzing noise (even on mute). My only remedy to drown out this interference is by ramping up the volume, which sometimes actually fixes the...
Do you have any other nearby devices that emit radio frequencies like a wireless router or a cell phone? I have had issues with buzzing on some of my speakers when my cellphone was nearby.
Oct 15, 2013 | Audio Players & Recorders
Realistic pro-62 scanner emits high frequency buzzing noise after half hour or so of being switched on?
There is a problem with something breaking down in power supply side. It could be a filter capacitor or a semiconductor.
Apr 18, 2013 | Radio Communications
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
TV EMITTING A BUZZ NOISE
You have a cracked Plasma panel. If u remove the back cover of TV and look in the top left of the plasma panel u will see a small round cylinder tube with glass tip inside. Look with a flashlight and u might see the crack. OH the buzzing noise is from the current going through the panel just not ignition the gases inside the panel to light the phospher cells. Hope this helps.
Apr 15, 2008 | Televison & Video
Loud buzzing noise
It is normal with xbox 360 it is just your system cooling down...
Jan 21, 2008 | Microsoft Xbox 360 Console
Buzzing emitted by vsx-409
Could be the result of having DTS compatible equipment connected through the analog inputs on the VSX-409D. Noise and distortion will result as essentially the DTS signal is being played back undecoded. If this is the case you'll have to connect your LD or CD player through the digital connections (coax or optical) and set 'Signal Select' (button on front) to 'Digital'.
Jan 06, 2008 | Pioneer VSX-D409
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
Canon PowerShot G2 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
