Hi there, I have a samsung top loader washing machine SW80SP, the has been some grayish mould like stuff in my tub for the last couple of washes. I did a "clean tub" cycle with jabola in my maching but it still seems to be there a bit. I have a baby so Im worried about this stuff getting on his washing. The user manual I have seems to be missing the "clean tub" cycle information. Can you please tell me how to get rid of this? & where it may be coming from? so I can clean it properly. Thanks, Shannon
SOURCE: Black stuff in washing machine
You need to clean the filter out (look in your machine - it's on the side of the tub) then run a wash with a cup of vinegar in it (or on soak with napisan or something like that in it). It's just gunk build up.
Posted on Feb 18, 2008
SOURCE: Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Posted on Dec 10, 2008
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: Hi we have a Fisher
You might have some junk in the pump. I have an older service manual you might want to look through to give you an idea how to get to the pump. The pump on these has a locking tab you lift then twist the pump a hair and it drops right out. Service manual
Posted on Nov 22, 2010
What is the Aqua Preserve button for? It does nothing when pressed during a wash cycle.
Hi it reduces waste of water by reusing last rinsed out water ...won't function when u select rinsing twice ..cheers
Jul 15, 2017 | Samsung Washing Machines
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
Washing machine won't wash when on large cycle
without stating the make and model it makes it harder for us to help you figure them out .front loaders are more prone to this type problem than top loaders .could be the gear box is going bad or a belt getting stretched
Oct 06, 2015 | Washing Machines
Hot water washing
You need to replace the water inlet valve.
Nov 10, 2012 | Washing Machines
My samsung top loader washing machine has black rubber like stuff when washing. How can I remove this stuff?
Hi all of them does it that is the staysoft having a reaction.only thing to do is to full it with water and remove the drian plug at bottom of machine to remove it.hope this helps
Mar 21, 2011 | Samsung SW62ASP Top Load Washer
Hi I have samsung top loader washing machine.Now i could here some water sound inside the washing machine when is shake the washing machine i.e below the tub..I just want to know what is the problem...
the inner bowl has whats called a balance ring which means the top layer ring around bowl has water inside to keep washer balanced...this is perfectly normal
Dec 28, 2010 | Samsung SW62ASP Top Load Washer
Hotpoint Washing Machine smells mouldy as has mould
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jul 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine cold water not filling
Typically this indicates that you have a water inlet valve that is not opening. Replacement of this part would be ideal, and should fix the problem.
Regards
Brian
Sep 10, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
