I have a Mitsubishi 65" rear projection TV that has only a fast
Green flashing light on the front panel, after unpluging the unit it still returns to the fast flashing light the bulb is cool and the remote will not operate the TV
  • 240 Answers
Having the model number would help.
green light flashing is telling you that it is in shutdown mode.
with model number we could reserch it futher.
Posted on Jan 12, 2009
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Power outage tv never came back on
Unplug connector zn under front speaker panel if it comes on with remote replace this part. If fails to come check DM caopacitors generally also cause this problem
Feb 07, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Flashing green light on mitsubishi ws-65513. replaced the four capacitors still have a blinking green light
Hi my name is Roety,
I can help you with your issue ,
Most likey you have a stuck keypad button, unplug the keypad from behind the front panel
If thats not it check for a fluid leak
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Nov 19, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Tv won't come on. It has a flashing green light on by the power button.
the tv is not come has a flashing green light model hd 1080.
Oct 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi 65 inch Diamond rear projection
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Won't power up
This model has had problems with the keyboard buttons on the front panel,causing them not to work and canceling out the remote operation. To verify this,you need to remove the front panel so you can access the connector on the keyboard pc board and unplug the connector.After doing this,see if the remote control is able to turn on the tv (wait for it to power up because with the connector off, the green power light will be disconnected and will not light up when the tv is on) If the tv works, than you will need to change the ten individual switches on the board - part# 432P089010 (or just use the remote only)
Aug 21, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Televison & Video Logo
292 people viewed this question
Top Televison & Video Experts
