Washer won't spin. Worked fine 2 days ago, no unusual noises, etc. Just won't spin
  • 45 Answers
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 12, 2009
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hotpoint WMA35
Remove lower rear cover of washer, remove belt, undo 2 screws securing motor, remove motor wiring plug,, lever back motor and remove motor.
Remove carbon brushes at end of motor, and check for wear, if less than 8-10mm long, then replace them.
Clean armature with emery cloth or sandpaper before fitting new brushes, if it still does not work then the motor is probably faulty.
Plz rate my solution.
Thanks.
Jan 23, 2009 | Hotpoint WMA35 Front Load Washer
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Kenmore 23812 top load washer
The lid switch is ususlly the first to go. Luckily, it is easy to replace. To test the washer, connect the lid switch wires together. If the washer spins, you need to replace the switch.
Jul 06, 2008 | Kenmore 23812 Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
