Question about Kitchen Appliances - Others
Foodsaver vac 540 wont seal bag - Kitchen Appliances - Others
  • 11 Answers
SOURCE: Tillia Foodsaver VAC 370 won't stop vaccuming to seal
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
Posted on Jun 25, 2009
SOURCE: My Foodsaver Vac 1050 doesn't extract all of the air from the bag
Either the sealing strips are dirty letting air escape or the lips of the bag are turned upwards. Push the front of the bag down towards the bottm chanel and it should work fine. I have had one for eight years now and love it.Ken Vancouver BC
Posted on Nov 21, 2009
SOURCE: Tilia Food Saver Vac 420 sucks air but won't switch to seal mode
Thanks to Mikeytheeye!!!
I became frustrated and figured I had nothing to lose. I had no idea what a vacuum switch was, but I took it step by step and moved on. It happens to be the round brown piece that has the tube coming in on the board.You have to remove the six small screws to the board and flip it. I tried to remove the "star" screw without removing the switch from the board, couldn't do it (also, I only had a t25 star screw attachment that worked at first, but started to strip). You can turn the switch but it does not open. I waited until the morning to make a home depot run and got a t27 star attachment and a soldering kit (only $18). From there, you just touch the two points and the switch comes off. I also got the contact cleaner ($3) and let soak. After cleaning it out and letting it dry I put everything back together and nothing happened. I took everything apart again and I tightened the star screw down almost all the way. Put everything back together and presto - the sealer worked after the vacuum cycle. For the record, we have a Foodsaver v345 model. Thank you for all the help.
Posted on Jan 02, 2010
  • 86 Answers
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
heatman101
  • 43501 Answers
SOURCE: foodsaver vac800 not sealing bags any way to fix
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Posted on Sep 16, 2010
Testimonial: "20 mins. got my answer fast thanks"
Foodsaver V3835 seals but will not sufficiently vacuum.
Go on the Foodsaver website to get replacement foam rubber seals that contact the bag during the vacuum process.
Feb 17, 2017 | FoodSaver Kitchen Appliances - Others
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
Foodsaver wont vacuum v3230
Make sure you put the bag in as it's designed to go in, I s**t you not I tried to use a wider foodsaver bag and cut it down but I inserted it the opposite way than it was intended to go in and it would NOT vacuum the air out. So I cut another bag to test if inserting it the correct way would matter....and it TOTALLY worked fine! Crazy how I couldn't get it to work the other way.
Jun 30, 2012 | Kitchen Appliances - Others
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
I have a foodsaver and it sucks the air out but won't seal. What do I do? We're trying to save some frozen fish and it just sucks and sucks but doesn't stop or seal. Any ideas?
The bag is wrinkled or the gaskets are leaky, it has to pull down to a set vacuum in order to shut off and heat the strip to seal the bag. For the right now dilemma try pressing down on the lid while it's vacuuming and start looking for gaskets at foodsaver.com
May 29, 2010 | Tilia FoodSaver V2240
V3460: no response when pressing seal and inserting bag. What should I do? Thanks
  • Assuming that the unit is plugged in and the plastic bag is in the proper position.........
  • Press firmly and equally on both sides of the cover (where the three raised ridges are on each side). The 2 micro switches that start the vacuum motor are located there and require firm pressure to operate properly.
Jan 20, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Dec 30, 2008 | Tilia FoodSaver VAC420
Kitchen Appliances - Others Logo
62 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
