Question about Little Giant VCMA-20ULS Condensate Pump
How to clean LITTLE 554425 VCMA-20ULS PUMP - Little Giant VCMA-20ULS Condensate Pump
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my little giant 554425 will not come on
Either the float is stuck or the pump is stuck...
To release the float a good shot to the side of the pump is all that it will take....
If that does not work then a few screws and the top will come off.. the pump is a very simple spinner.. make sure ther is nothing jammed in there...
if that all checks out replace the unit, the motor is shot....
you should be able to find a new one at a HVAC supply house for around fifty bucks...or check www,grainger.com for a replacement condensate pump.
heatman101
Posted on Apr 07, 2010
SOURCE: Little Giant Condensate VCMA-15UL pump. Pumping when the float was down.
new pump
Posted on Nov 12, 2012
  • 166 Answers
Little Giants are noted for having faulty float switch problems----even the new ones----a major HVAC company I worked for discontinued using them because of this----they remove 1 to 2 years worth of installed pumps and substituted another to because of warranty no heat/ac/flooded floors call backs and returned all of them to the mfg including all of the stock they had---for life of me I can't remember the name of the new ones---when the float failed it would shut down the furnace or ac and usually flood the floor by NOT pumping --- being a service warranty----the pump was replaced not repaired---they probably could of been repaired though with another float switch such as what could be done with yours---that's all I got--good luck
Posted on Mar 03, 2015
Little giant pump 554425 pumps water every second continuously. What could cause the problem?
It sounds like it there is a bad check valve but I can only guess. The part number you gave is for the switch. A better description of the problem would be helpful.
Sep 18, 2013 | Little Giant Pump part 950337
My Little Giant VCC-20ULS is making a very strange noise and leaking water What do I do? or who do I call for repair?
Hello, Most likely the pump just need to be cleaned out. Turn power off and clean out pump with soap and water.
Aug 16, 2011 | Little Giant Plumbing
Little Giant 554455 VCMA-20ULS 230V 20' My pump runs when the float is down low in the tank and comes off when the float is high in the tank. So it runs continuous. Has something gone wrong and...
The float switch went bad... probably because of the water...you could replace it, but the parts are hard to get and with the time involved it will be easier and cheaper to replace it...
heatman101
May 29, 2011 | Little Giant 554455 VCMA-20ULS 230V 20'
How do I wire the safety overflow switch to my furnace humidifier thermostat? I have a Little giant VCMA-20ULT and a Aprilaire 700.
The overflow switch needs to be wired in a manner that interrupts the HOT (black?) side of the wires going to the water inlet valve or it's circuit.
Feb 28, 2011 | Little Giant VCMA-20ULT 80 GPH - Automatic...
My little giant 554425 will not come on
heatman101
Apr 07, 2010 | Little Giant 554425 VCMA-20ULS 115V 20'
The VCMA-20ULS pump is not shutting off
These pumps have a float arm inside that tell the pump when to turn on and off, it sounds like your arm is stuck or broken. The top of the unit can be taken off of the reservoir to check for damage.
Good luck
Sep 29, 2009 | Little Giant 115V 60Hz Condensate Removal...
Little Giant VCMA-20ULS Condensate Pump Logo
121 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
