Question about Coffee Makers & Espresso Machines
Rocket cellini hot water steam valve is leaking
I want to replace the hot water steam valve
z34aga
  • 137 Answers
SOURCE: leaking steam valve rancilio miss audrey
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
Posted on Apr 02, 2009
  • 1089 Answers
SOURCE: I have Saeco Royal Coffee Bar. Hot water and
Hi
You may have a flow meter that is bad. If its white plastic check for corrosion at the wire terminals. If your have corrosion change the meter and you should be good to go.
Posted on Jun 01, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Incanto - No water through the coffee brewer
Check the line where the water goes to the brew unit(be careful), disconnect and try to brew coffee, if water exits then the blockage is elsewhere, check the line where it goes into the white plastic valve behind brew unit, if water flows then check the brew unit make sure it is not blocked at the screen.
Posted on Jun 09, 2009
  • 81 Answers
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Posted on Feb 03, 2010
SOURCE: Impressa E8 water leak
Did anyone find an answer to this - sadly we have the same issue.
Posted on May 04, 2010
Saeco incanto deluxe frother leaking and wont pull shot because water comes out of frother tube during shot disbursement
Dear Jon,
Hi this shrikant from mumbai.This problem is happen due to dust stuck in tea/hot water valve ( for steam which you rotate).
If you have screw driver set then open the machine by using + screw drive. step below,
1.I here attach picture of valve.
2.you have to open it and clean it ( sea in pic 44,46,47,54).
3.after water leaking stop you have replace one o-ring 54 no. in picture.
4.After you machine work fine.
regards,
Shrikant Shinde
Yogishri Engineering
+91-8425830001
Jan 28, 2015 | Saeco INCANTO DELUXE Espresso Machine
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
Tip
Ventilate error -
The following procedure works when you get the ventilate error:
The Ventilate sign can be due to one or more of the following reasons:
Cause 1- Water leaking from the inlet valve below the water tank. The hose from the inlet valve to the pump can be air locked. When using the hand pump, do not thrust its nozzle too deep
Cause 2- Blockage in the passage of water due to clogged passage anywhere between the pump and espresso delivery nozzle.
Cause 3- Pump is not working. Open steam/water outlet knob and hear the pump work. If you do not hear any noise from the pump, this may be the main cause.
Cause 4- Flow meter is faulty. This part is like the water meter for homes. It measures the flow of water and signals the electronic board. The malfunctioning flow meter will not send signals even when water is flowing through it.
Cause 5- Hose is disconnected and water is not flowing in the system.
Cause 6- O-rings at hose connection is leaking, reducing the water flow to be sensed by flow meter.
Cause 7- Boiler gasket is leaking. Reduces flow of water through the system.
Cause 9- Brew unit is blocked, blocking flow of water through the flow meter. This also causes pump to slow down and ultimately stop with muffled sound within 15 seconds.
Cause 10- Brew unit not connecting brew valve, preventing flow of water. Same sign under cause 9.
Cause 11- Steam is leaking. Registers reduced flow of water at the flow meter.
Cause 12- Solenoid valve is blocked or solenoid coil is bad. Same observation as cause 9.
Cause 13- Electronic Control board is bad. Though rare it can happen due to condensed water from leaking steam. When steam is leaking or boiler is leaking, machine should not be used any more to prevent steam shorting the Electronic board.
Some of the above causes can be checked and corrected before seeking technical help. Do not assume anything without physically checking each of the following:
1- Make sure the water tank is full. If the water tank has water level float, make sure the float is in its housing and it floats as water is filled in the tank. If the level float does not rise with the level of water, then replace the float.
2- Water is not leaking from below the tank. The inlet valve is good. If leakage is present, replace the gasket in the water inlet valve.
3- Prime the machine by opening the hot water knob for 20 seconds or pressing the hot water button. Hot water flow shows the boiler is not blocked with minerals and pump is good. The solenoid valve is good.
4- Water & steam flowing normal, check the brew group for blockage. Determine when was the last time brew group was cleaned. Clean the brew group as explained elsewhere on these pages. If the machine has pre-ground function, try making a fake espresso (without coffee). Make regular espresso in other models to make sure that water goes through brew group and espresso is dispensed.
4- If hot water does not flow because the pump is not activated, then pump is bad. Replace pump.
5- Pump starts to work but within few seconds its sound is muffled and finally stop. This indicates there is serious blockage in the water line or the boiler is clogged with mineral deposits. If water is leaking and seen on the counter top, the chances are that water is leaking from hose connections(replace O-rings) or the boiler is leaking from seams (replace boiler).
6- Prime the machine by opening steam outlet for 20 seconds. Steam flow shows that steam boiler / steam outlet is not blocked. If the steam does not flow, then steam boiler or steam passage is blocked. Replace steam boiler or steam valve
7- Check the solenoid valves to make sure that they open & close as the coil is energized. Solenoid valve is located between the pump and boiler. The pump is activated simultaneously as the solenoid valve when espresso selection button is pressed. Some models may have a solenoid valve near the steam valve. In these models, the solenoid valve is activated to allow passage for steam/hot water. If the valve is not functioning, the ventilate sign will appear.
7- Hear the pump work when priming the machine. Louder noise from the pump can be due to
** air-locked water hose, or
** water is not sucked from the tank or the pump is sucking air instead of water or
** the diaphragm inside the pump has lost flexibility and not developing pressure to push water forward
** the hydraulic system is blocked at one or more locations due to mineral sediment. Find the location and cause of the block and correct it.
** Clean the brew unit (see cleaning instructions) and make sure that
a- the ground coffee used is not powdery fine.
b- The dose of coffee grounds is not in excess specification
c- check if there is blockage. Find the cause and remove it.
8- If steam and hot water flow is normal, but the ventilate sign persists, then the flow meter or the electronic control board is bad. Replace flow meter or the control board, as necessary.
Try also the following:
  • Press hot water button once. Message on the screen will not change, this is normal.
  • Open the steam knob and allow the water to flow freely from steam wand into a cup. The screen should now read "Hot water,ventilate", you may need yo empty several cups of water before message changes. In some case it is necessary to refill the machine container without interrupting the operation.
  • As soon as the screen displays "hot water," turn the steam valve off .
  • If the machine warms up again, then problem is fixed.
on Jan 21, 2011 | Saeco Magic Comfort Plus Espresso Machine
No steam coming out
follow this steps and fix it. God bless you
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Nov 28, 2013 | Westinghouse Irons
My Titanium leaking water. Under it
The steam valve assembly that the steam knob on the right hand side connects into is probably faulty. When you're steaming if you hear hissing coming from behind the knob then this indicates the connections into this assembly are leaking steam, and also hot water, which is why you're getting puddles under the machine. You can get a replacement steam valve assembly that fixes some issues with the original (part code SVM-17, available from www.partsguru.com) and will prevent the leakage, or you could simply try opening the top of the coffee machine and removing the tube that runs from the boiler into the steam valve. It has two o-rings that provide the seal where it connects into the steam valve assembly, and if you lubricate these with a food grade silicon lubricant it may fix the problem. My Gaggia is 7 years old so I decided to replace the whole assembly which costs about $50 and that solved the problem completely.
Apr 04, 2011 | Gaggia Titanium Espresso Machine
Why does steam wand on dualit espresso leak
The wand can leak if the rocker switch is not in the UP position.
In MIDDLE position it will try to deliver hot water.
In DOWN position it will try to deliver steam.
The thermoblock in this unit is actually a 3-way valve, of which two positions route water from the boiler directly to the wand. The 3rd position (UP) routes hot water (but not steam) from the boiler to the group head.
Try holding the switch in the UP position by hand when making coffee. If the machine still pushes water through the wand then you will have to replace the switch inside the machine that is activated by the rocker, or the valve it operates.
Please let me know how it goes.
graham dot r dot leach at gmail dot com
Oct 01, 2010 | Dualit Espresso 889 Espresso & Coffee...
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Feb 03, 2010 | Saeco Odea Go
Water is leaking into the drip tray.
Clean the chamber below the white plastic valve, there is also a small discharge that leads from there into the drain tray clean that hole also.
Second the thermostat that controls the steam may be damaged or the cpu board, the contact the controls the steam may be damaged, i have seen both of those happen on some units.
Oct 10, 2009 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
