SOURCE: vitantonio waffle maker
It sounds as if the iron isn't cooking at a high enough temperature. I'd try turning the iron to the highest setting, first (the thermostat may not be giving a correct reading, keeping the temp too low), before considering getting a new iron. The good news, though, is that a new waffle will only set you back about $20
Hope that helps
Please rate accordingly
Thank you
Computerrep
SOURCE: No heat on brand new Waring WMK300 waffle maker
Lots of appliance makers include a 1 800 number with the paperwork that comes with an appliance.
I would try to find that number and call them. They owe you a replacement unit. If you can't find the number do a Google search for Waring and they should have a tel number and/or a "contact us" place to send and email.
Good luck Loringh
SOURCE: removing top of waffle maker to clean it
The other night my wife had the same issue. My thought had always been to wipe it down using a wet cloth with simply hot water and rely on the extreme heat of using it to sterilize it. My wife decided instead to disassemble it. The problem is that it is not made to disassemble and she bent some parts and broke others and stripped out screw heads. It is clean now, but can not be reassembled without extracting stripped screws and replacing some parts. My advice to you is - don't try to disassemble it. The factory went to great lengths to ensure that you don't. Instead use a soft cloth dampened (not dripping wet) with the hottest water you can.
SOURCE: I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
SOURCE: I need a manual for a salton waffle maker wm4
There is a site that posts PDF files of manuals for all manner of things..manualsonline.com.
Here's the link for the Salton Waffle maker, they have several versions:
http://kitchen.manualsonline.com/search.html?q=+salton+salton+waffle+maker
