Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Can't install Epson SX100
During install, when I plug the USB cable in, the 'Found new Hardware Wizard' starts then reports that it can not install this device - "The parameter is incorrect'. The wizard reports the device correctly as Epson Stylus SX100. I am using winXP. Epson Support have told me that this is a WINXP problem and that there is a fix for it - something to do with a hard drive conflict. I can't find any problem listed in the MS Knoledge base. Has anyone come across this problem and know the fix? I have installed the printer on a differnt computer OK.
  • 2 more comments
  • Anonymous Jan 13, 2009
    I have further info on this problem. It appears not to be the printer. I have tried another printer on the paralell port and I get the same error. All other USB devices work fine. I have tried the printer on another PC with the same motherboard and almost identicle build; it gives the same error. But another PC using a different motherboard works fine. The board in question is a Gigabyte GA-M61PME-S2 so I am trying Gigabyte's support page.
  • Pietro Pedrazzi Mar 19, 2009
    In one portable PC, running Windows XP Home, the procedure for installing the printer's drive doesn't stop for asking to connect the printer's USB cable, but it suddenly ends with a message like "Installation OK".
    Instead, the installation of the drive is NOT OK at all, and the printer doesn't work.
    Must be noted that the scanner mounted on the printer DOES work.
    In other PC the problem doesn't exist.
  • Anonymous May 17, 2009
    When ths Epson SX100 drivers are installed one shall plug in the USB cable. When I do the printer is not recognized, the printer cannot be found. However, the printer IS plugged in, Windows finds it, the new hardware wizard starts. But you cannot install the printer via the Windows hardware wizard because the USB port is not created.
  • Thomas F. Schneider May 11, 2010
    You might try the EPSON site for a solution?
    http://www.epson.com/cgi-bin/Store/suppo...
I found the right solution, at least to problem #2 on http://spazioiberico.spaces.live.com (in italian),
referring to http://www.tech-archive.net/Archive/WinXP/microsoft.public.windowsxp.hardware/2005-10/msg00987.html :
there was a missing Key in the Registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E979-E325-11CE-BFC1-08002BE10318}
Copy that key from a working PC, that's all. By the way, if your problem regards a scanner o camera instaed,
the missing key may be:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
Posted on Mar 23, 2009
I have put the cd for installation of the printer but invain
Posted on Apr 19, 2009
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a4
Posted on May 22, 2009
Hi re epson printer SX115 - red light flashing - error being reported - P/C does not recognize printer rgds chris
I suggest you uninstall the printer and restart your computer. Plug in the printer and if the computer recognises it allow the found hardware wizard to install it. If it doesn't recognise the printer when it is plugged in I suggest you assume the printer is faulty.
Jun 06, 2016 | Epson Office Equipment & Supplies
When I plug my Samsung Galaxy S5 into PC, the Found new Hardware wizard runs and then appears a notice: "There was a problem installing this hardware: SAMSUNG Mobile MTP Device An error occurred during...
Make sure the camera is not plugged in. Go into the Device Manager and delete the camera. Shut the computer down. Start the computer. Use the browser to search for the latest driver for that camera and your present operation system. download the drivers and install them. shut the computer down. plug the camera in to the USB and start the computer. It should find the hardware and if it fails to install properly then, you must choose the driver that you have downloaded to install the driver that way.
To make it any simpler, I need the Make and Model of the hardware and the OS you are using.
Mar 23, 2015 | Microsoft Windows XP Professional
When i try ti install my printer i get a meaasage saying "the specified location does not contain information about your hardware" what does that mean?
The message means that the printer driver is not available or is corrupt. You can click on the link below and download the driver and start fresh.
Click Here >>> iP2600 Driver
Also, below the is screenshot of the website, click on Driver & Software button and select your Operating system to get the specific driver.
Regards,
Shrey
Jun 02, 2011 | Canon Pixma iP2600 Photo InkJet Printer
I cant find the Cd for instaalling the Epson stylus Sx100 what can i do
1st You download Printer Driver. Epson Stylus Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Install
Epson Stylus ->NOT plugged into electricity, ->NOT plugged into the computer with the USB cable, and Windows running on your computer.
1.Place the CD disk that came with your Epson Stylus in your CD or DVD drive. Install the contents to your computer. Restart your computer.
->NOW, plug the USB cable of your Epson into your computer. Plug your Epson into power.
If you hear the Epson setting up, wait until it has finished, before pressing the Power On button.
Press the Power On button of your Epson Stylus. You should get a "Found New Hardware" pop-up, out of your task bar tray at the bottom of your desktop screen.
IF, you have already connected the USB cable from the Epson to your computer, and turned the Epson on, BEFORE you installed the software from the CD, you have to start over.
You have to wipe off the Epson software First, before you do.
Start>Control Panel>Add/Remove Programs.
After Add/Remove Programs has fully loaded,
(Please wait for the list to be populated), scroll down through the list, and -> Remove <- anything you see listed with the Epson name.
It will ask if you wish to restart your computer at this time. Yes! Restart your computer.
After Windows has loaded, follow what I have printed in number 1 above.
Jul 12, 2009 | Epson Stylus CX6000 All-In-One InkJet...
If I plug it into the laptop it makes the sound when a USB device is plugged in. It says found new hardware, then it wants to install the hardware with the Wizard all goes well until the wizard tells
It seems the Operating System does not have drivers for your new device or some portion of the drivers are corrupted. If you have the drivers cd for the USB stuff, install the drivers without attaching it to the pc ok. Attach the device when prompted or when completed. Make sure that any previous installations of the software and/or the device should be uninstalled. Good luck
May 04, 2009 | Computers & Internet
New hardware might not work properly
Right guys, found the sollution:
Right click on My Computer, Choose Properties from the drop down list, then click on Device Manager.
Down the list, there will be Universal Serial Bus (USB) controlers. If this selection isnt expanded already, click on the + icon next to it.
In the list that pops down, there will be an entry called IPod and it will have a yellow question mark on it. Right click on this, choose properties and then click on update drivers. Follow the install wizard and then voila! It will be installed.
Have fun guys!
Jan 06, 2009 | Creative Labs Zen Micro MP3 Player
Cant install canon ip90 printer. Downloaded driver not found by wizard.
Do this:
In XP default view, from the Start menu, select Printers and Faxes, and then double-click Add Printer.
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
Uncheck all options except
Specify a Location.
Click Browse.
Browse the folder where you have your downloaded driver
OK.
If the driver not match you have a wrong driver.
In that case go back to Canon and get the right one and do the same procedure again.
Have a great day
Pablo :-)
Oct 21, 2008 | Office Equipment & Supplies
I recently bought a HNC model CTGJD2028 3D Optical USB Plug and Play Mouse for my Compac Deskpro EN running XP Pro. Plugged mouse into usb port. Get a Popup Bubble – Found New Hardware – Mouse. Message...
UPDATE YOUR WINDOWS SOFTWARE FROM MICROSOFT OR YOUR VENDORS SITE, THERE MAY BE MORE SOFTWARE PATCHES FROM THE VENDOR TO FIX THAT TYPE OF PROBLEM
Aug 11, 2008 | Computers & Internet
Trying to install HP C4280, fatal error comes up during installation and will not complete
To install that printer, connect the data cable (Maybe USB?) to the PC and follow the instructions on the "New Hardware found" wizard, then supply the CD that came with the printer and make the wizard look for the drivers there. When the HP install program pops up (Gray sandglass), choose "Decline" or "Not agree" to the terms of the license and continue with the "New hardware wizard" installation.
The printer driver will get installed and none of the HP useless programs.
May 04, 2008 | Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
2,396 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
