Question about Toshiba Televison & Video
Volume spike model # 32c100u2 Intermittent volume spikes, during commercials or a regular program. Have to manually turn off tv to correct. TV volume spikes to a very loud volume all by itself at differrent times of the day or night
  • 395 Answers
SOURCE: Volume suddenly turned down during commercial
shut off the all BBE and surround and the AL sound page 27 of the manual.
Posted on Apr 01, 2008
ramon49
  • 111 Answers
SOURCE: 32 inch tv goes from normal sound during program to extreme loud
May be a defect but, if you notice the sound changes with different channels or movies or HD or Standard, look for a volume limiter control button in the menu setup under audio control. Sometimes the menu has a control that you can turn on to limit different volume levels during the shows origination.
Posted on Mar 12, 2009
  • 11800 Answers
SOURCE: We have a visio flat
Go in the tv's Menu, Sound section. In there you will notice an option called Normalisation - it does exactly what you want: it raises the weak sounds and lowers the loud ones. Enable it.
Posted on Dec 27, 2010
SOURCE: I have a new Vizio
I have exactly the same Vizio model TV and I have exactly the same problem
SD Tech
  • 14553 Answers
SOURCE: My Coby TV LEDTV 1926 turns itself on. This happens at random times, sometimes during the middle of the night, sometimes during the day. How do I turn off this annoying feature?
Does the set have the Guide Plus feature?
Posted on May 01, 2012
Can I control the volume of commercials with my remote control? They get real loud.
yes, you can turn the volume of the TV down or mute it during commercials.
Mar 04, 2015 | Sharp Aquos Televison & Video
No picture model Toshiba TV model #32c100u2 get
Does it have a DVD player Combo unit ???
Aug 16, 2013 | Toshiba Televison & Video
Sound on my rca tv
I wonder if your problem with loud volume occurs primarily on commercial breaks, when you turn down
the sound and then, since the sound, for the program itself, is so low in volume, you have to turn it way
up again to enjoy the program?
If this is the case, and there are no other problems with the set, this may not be the set's problem, but the
fact that commercial material is broadcast at a higher volume than program material by some outlets, so
that while you are in the kitchen, during commercials, the sound of the commercial can still be heard.
Apr 18, 2009 | RCA Televison & Video
Mar 12, 2009 | Televison & Video
Spectroniq PLTV-20NW32 volume only works on some channels
Hi lisadean767,
It is possible that without realizing, your TV is programmed to receive SAP or Second Audio Program audio. When this happens, your TV responds like this: when SAP is not being broadcast, you'll receive regular program audio. However, when the SAP audio is sent along with the regular, (English) program audio, your TV will automatically switch to the SAP channel. You'll know your TV is programmed to receive SAP because you'll hear the commercials in English and any other program in English if the SAP is not being sent.
Check and see if your tv is setup for SAP. Let me know if this helps and if I can be of further assistance, Please rate this solution.
Lone99star
Jan 22, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
High and Low sound volume
Now volume is relative to the person listening,
so based on when you can hear the tv correctly during a normal show,
if you hear normaly we will call that 50%
how much louder does it get on commercials from 50%
there are in the menus different sound fields, have you found out how to change them? Take the tv out of surround mode and see if that helps. Just set it to stereo.
give me a model # and I will tell you where in the menu it is if you cannot find it.
I also need to know, are you running through an amp?
Do you have a cable box, because in those there is also a setting for surround.
it sounds like you have surround set, but no surround speakers.
i'll be here
Charles
Jan 10, 2009 | Televison & Video
TV sound much louder on commercials
It is Not your TV this is done by advertisers to get your attention and it works
Dec 23, 2008 | Insignia NS- 27" TV27 TV
Feb 22, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Sound goes up from tv show to commercial
There are two reasons for this. Firstly, the commercial channels are deliberately boosting the volume during commercial breaks to grab your attention. Secondly, the commercials use compressed audio (narrow dynamic range). This often comes across much louder than program material, which is using a wider dynamic range on which you would have based your volume setting. It is noticeable that the BBC are also sending out wide variations in volume at present - Yes it is VERY annoying. Some sort of ALC (automatic level control) is required but this would need to be switchable. Hope this helps.
Sep 26, 2007 | Yamaha RX-V620 Receiver
Commercial skip/blackouts
Sounds like you're blessed to have a tv like that! Seriously: Some sets have settings that will cut down the sound during a commercial. Haveyou looked at your owner's manual? This tv may have setting to cut out the picture also when commercials come on. From a technical view point generally commercials have stronger signals than regular programming. This may be overloading your set. If this is the case, then you need to have it checked by good technician. A poorly operating power supply (not regulating properly) could possibly cause a problem like this. Also automatic gain control circuits could be not working properly. Stargazer
Jan 19, 2007 | Hitachi 43FDX01B TV
Televison & Video Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
