My daewoo full auto electric washing machine model: DWF- 177ME does not work. The power button comes on but nothing else that is pressed registers. Can you tell me why? It was bought 2 weeks ago so i
I can't understand why none of the buttons are activated when pressed but the power button works
3 Suggested Answers
  • 6277 Answers
SOURCE: My Daewoo wshing machine model:
Sorry - I do not have a list of error codes for your particular machine BUT as a guess, with no promises, try this!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 25, 2011
SOURCE: daewoo washing maching model dwf-760mp
daewoo washing maching model dwf-760mp nano silver, when i press start water comming out continously
Posted on Nov 25, 2011
DAEWOO WASHER DWF-800WPS machine the outer water is countune going out what is the problem
pump is running and not stopping, low water sensor is not working properly, replace part. it is behind control panel .
Jan 11, 2015 | Daewoo Washing Machines
Daewoo DWF 806 MF does not hold water
if the drain hose gets too far down the drain ,it can get into the water that stays in the trap and cause it siphon out of the washer.try pulling it back up about three inches and zip tie it off to one of the fill hoses,
Mar 15, 2014 | Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Jun 16, 2009 | Washing Machines
Dwf-6010ap
I HAVE DAEWOO WASHING MACHINE MODEL DWF-6010AP
THE PROBLEM IS THAT COLD INLET IS LEAKING WHEN RUNNING I NEEDS SOLUTION OR WHERE CAN I GET PARTS
Jun 25, 2008 | Daewoo Washing Machines
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
