Question about Kenmore 24032\24036 Top Load Washer
How to install lid switch?
I did need a lid switch, and have ordered it...is this something I can install? What do I do first?
  • Anonymous Feb 27, 2009
    lid switch instalaation
  • 242 Answers
Its an EASY fix , I can help , there should be 2 phillips screws on top of unit under lid holding the lid switch in place , unplug the unit and remove screws , the switch is now loose you should be able to grab it with your hand and pull it out to where you can see it , I recommend cutting the 2 wires going to it and using wire nuts to reconnect them to the new switch to make things easier. if you have any more probs. or questions please let me know.
Posted on Jan 12, 2009
Bentley Boot lid manual release
This is all the Bentley shows:
Location: Driver's side door trim in storage compartment.
Removing:
- Remove driver's side door trim:
Repair Manual, Body Interior, Repair Group 70 - Unplug connectors.
Carefully disengage catches -arrows-.
- Press switch for interior monitoring and towing protection -1- or trunk release switch -2- out of trim toward rear.
Installing
Installation is carried out in the reverse order.
Remove trunk lid lock.
Repair Manual, Body Exterior, Repair Group 55
- Use a flat screwdriver to pry plastic tab -3- off retaining pins -1-.
- Bend plastic tab fully to rear.
- Pull contact switch -2- first sideways and then up and out of trunk lid lock.
Installing
Install in reverse order, paying attention to the following:
Note:
Make sure that washers are correctly seated between plastic tab and trunk lid lock.
Sep 01, 2012 | Bentley Continental Flying Spur Cars &...
My GWL11 wouldn't drain or spin. I tried to restart the cycle and it lost power. Help my kids are wearing filthy clothes. :)
  • The first thing to check is to see if the motor is running if the motor is not running then you need to check the lid switch and see if it still lines up with the hole it goes into when you close the lid. This pin can get bent from slamming the lid as well as broken from old age and becoming brittle.If it is not there altogether it will need to be replaced and installed. You will need the make and model number of your machine and you can order parts through this web sitewww.appliancezone.com.they only charge5.95 for shipping and they ship same day.
  • The installation is sometimes easier than getting to the place to get at it to install it. If this is something that you do not want to do you can call a professional to come and do it . If you want to do it yourself you will need step by step instructions. please write back if this is not the problem or if it is and you want instructions on how to install it. Thanks for choosing fixya.
Oct 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Roper TAWS800JQ1 will not operate while lid is down. I have to manually stick something into the hole where lid stick goes in order for the washer to rinse and spin. Are there any solutions besides a...
Try gluing (with epoxy) an extension to the lid switch actuator. The other option is to remove the cabinet top and replace the switch. Unplug the power before doing this. Hope this helps!
Oct 02, 2010 | Roper Washing Machines
Kenmore 80 series washing machine will fill up with water, then nothing happens
Kenmore Ultra Fabric Care Heavy Duty 80 Series washing machine (Model # 110.92389200; Serial # CF 1122814) went through the wash cycle completely, but rinse not the rinse cycle. Motor was going but washer not spinning. Also smelled something like burnt rubber. Could the belt have gone out? Is this something that I can fix myself?
Mar 18, 2010 | Washing Machines
The washer does not drain the water or spin. Does the drain work when the spin cycle starts?
pull end caps from both ends of back splash remove 2 screws flip control panel back...remove 2 clips(use screw driver to pry up)...disconnect wire plug lift lid put hands in opening pull the case to you and up to remove entire case...remove 2 screws that hold lid switch install new switch...(don't forget to plug the wire plug back in...ho ho
Aug 26, 2009 | Kenmore 23822 Top Load Washer
My machine will agitate but it won't spin and drain. For a while I fixed it by finding something to press down where the lid button pressed down in that little hole, but now I can't get it to drain at all.
You shouldn't have to use anything to push the lid switch to make the washer work. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub in order to complete this repair. Once the lid switch has been replaced, the washer will drain normally. This may save you the need to bail.
Jul 11, 2009 | Washing Machines
Washer won't drain
The symptoms you describe are typical of a lid switch problem. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike.
If the lid switch is broken, you can find a replacement at searspartsdirect.com. If the model number you have this listed under is correct, just type it in the search menu at the Sears website. Type the model number in as follows : "110.1586400", or "110.1586200" to complete your search. A COMPLETE model number from the washer nameplate (located around the wash tub opening under the lid) would be more helpful. You can find the switch under the "Top and Cabinet" heading as item number 11. The lid strike is listed under the same heading as item number 20. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
If the lid switch is functioning properly, you may have something binding in the drain pump. The lid switch is an easier option to attempt first as it does not require you to drain the tub in order to repair. If the switch is not the problem, please post back and let me know. The drain pump is easy to replace, but will require some effort in getting the tub drained in order to install a new one.
Both repairs are inexpensive and can be easily accomplished on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
Nov 11, 2008 | Kenmore 15864/15862 Top Load Washer
Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Aug 29, 2008 | Washing Machines
Have to slam the lid
The same thing happened here. It turned out to be the lid switch. It can be accessed by taking off the back plate (behind the controls) by unscrewing three screws and two screw bolts -simple.
I removed the lid switch and tested it with an ohm meter - instructions are on this site. You should have continuity across machine-motor, as well as across machine -line. (These are labeled on the switch).
If you don't have a meter and you still want to see if that's the problem, after you have removed the lid switch, short the machine and line connectors, (you'll see these labeled on the lid switch so you'll be able to figure out which wires go with what) as well as shorting the machine and motor connectors. Both of these need to be shorted. That bypasses the switch and will activate the motor and controls.
That's what I did to confirm that it was all a "lid switch " problem. I ordered a lid switch from this site for $24.95 for the repair, and will use the "shorting process" to do a couple of loads of wash as I wait three days to get the switch. Good luck.
Dec 16, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
146 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
