Question about Franke Kitchen Ranges
Globe for trs60x
Franke 60 cm slideout rangehood
3 Suggested Answers
  • 72 Answers
SOURCE: A charcoal filter for a
Charcoal filters are normally purchased seperately. They are generally black in colour, if you shake them the charcoal granules make a rattling sound.
Posted on Dec 28, 2009
SOURCE: How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Posted on May 22, 2010
How do I change the gear oil in a food service mixer sp62
About 49 results (0.77 seconds) Search Results
    [PDF]Instruction Manual for Globe Mixers - Globe Equipment ...
    https://globeequipment.com/media/product.../Sp10_Owners_Manual.pdf
    Or call the Globe service department at 937-297-7247 and ask for contact .... Please remember that this manual or the warning labels do not replace the need to be alert, to properly train and .... gears or other parts and WILL void the warranty! 7. ... Lubricate the attachment shaft with a food quality grease or mineral oil. 4.
    SP62P 60 Quart Pizza Mixer - Globe
    www.globefoodequip.com/.../mixers/...mixers.../sp62p-60-quart-pizza-m...
    This mixer comes complete with an 60 quart stainless steel bowl, spiral dough hook and bowl ... High torque direct gear drive transmission; Oil bath transmission.
    Globe SP62P Gear Driven 60 qt. Commercial Planetary ...
    www.webstaurantstore.com > ... > Commercial Floor Mixers
    Commercial Planetary Floor Pizza Mixer - 3 HP. In stock ... What is White Glove service? ... Globe XXBOWL-62 60 Qt. Stainless Steel Mixing Bowl for SP62P Mixer.... Planetary grease fitting and gear oil meter. .... Globe SP62 and SP80PL MixerControls .... 2003-2016 WebstaurantStore Food Service Equipment and Supply .
Jan 30, 2016 | Globe Food Mixers
Torin E13 Rangehood. Blown light globe needs replaceing
Gee I think I could figure that out by looking at it .
Jan 17, 2016 | Kitchen Ranges
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
I have no book on a hyundai tiburon 1997 and i need the torque specifications on the head bolts and cam bolts.
1.8L
Head bolts:
(M10) 30 Nm (300 kg.cm; 22 lb.ft) + (60°to 65°) + (60°to 65°)
(M12) 35 Nm (350 kg.cm; 26 lb.ft) + (60°to 65°) + (60°to 65°)
Camshaft:
Using two or three steps, tighten the bearing caps to 12-14 Nm (120-140 kg.cm, 9-10 ft. lbs.)
Sep 24, 2010 | Hyundai Tiburon Cars & Trucks
Nov 17, 2009 | Kitchen Ranges
Charcoal filter for rangehood
The charcoal filter is for if you do not have the hood vent to the outside of the house. The charcoal filter does not come with the hood you need to buy it separately and It will tell you where to put in the instructions that come with it.
Good Luck And Please Rate FixYa!
Dec 27, 2008 | Franke Kitchen Ranges
A charcoal filter for a Franke BEV2 60 X rangehood - are they included and we just can't work out how to find it?
Dec 27, 2008 | Kitchen Ranges
Kitchen Ranges Logo
22 people viewed this question
Top Franke Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Franke Kitchen Range Expert? Answer questions, earn points and help others
