Question about Garden
How do you restring a rotary clothesline - Garden
Why will my Hills Hoist /villa 37 "free-wheel"......there is enough breeze.
Hi Bonnie,
The Hills Everyday Villa 37 has a breeze brake which is the top section of the clothesline. What this does is locks the clothesline in position to allow for ******* on windy days.
To get the clothesline to Free Wheel you need to make sure it is wound up enough to miss this breeze brake section and allow it to spin in the wind.
If you are looking for more help you can further documentation on Hills Rotary clotheslines here https://www.lifestyleclotheslines.com.au/folding-rotary-clotheslines/hills-everyday-37
For replacement parts you can also find help and advice here https://www.lifestyleclotheslines.com.au/clothesline-spare-parts
You can also find a great video on this product here to
Jan 20, 2015 | Hills Everyday Villa 37 Rotary Hoist...
Restring clothesline hills
This may assist
"I found that Hills don't sell new line kits direct anymore, so I got some poly core line from Mitre 10, 60m for $30.
Study how the original line was strung through the clips and how it was tied at each end, and you will find that you have to remove 4 plastic wedges which secure the line in the end caps, these things
http://www.breezedryer.com/index.php?p=product&id=792
The wedge is not shown. You just push it out upwards. Then cut away and pull out the old line from all the clips, these things
http://www.breezedryer.com/index.php?p=product&id=741
Then tie the line onto one end cap as it was before, and restring the whole hoist. To get the line into the clips, you can carefully lever a bit with a screwdriver.
Don't worry too much about tension yet, just leave the line a bit slack on each run. You will have to pass the coil of line over the top of the arms many times. Finally cut it off after the final run, leaving enough line hanging down to secure the arms in a bunch when the hoist is folded up.
Make the final knot as it was, and then, without skewing the arms sideways, remove any slack going around and outwards, and finally pull in and tighten the final knot at the outer end, and replace the 4 wedges.
The line will stretch, so you may need this final step once more.
Sep 06, 2014 | Hills Rotary 8 Clothesline, Ocean
How to reline a hills rotary clothesline model FD88002
The Hills Rotary 7 Clothesline FD88002 is one of the new Hills rotary models and does have easy line replacement.
This Hills Rotary clothesline has a line tensioner and cap that covers the catch.
You will need a small screw driver to pop off the caps.
Next step is to remove the line from the tensioner
You would then thread the new line through and re-tension the line as per the instructions in the manual or video below.
You can find the Hills Rotary 7 Manual here for free download.
Hills Rotary 7 Clothesline Owners Manual FD88002 FD88003
Below is the video on how to re-tension the lines.
This is the replacement line that Hills make which comes in a 70m pack which is the length you would need if you are re-wiring your whole clothesline.
https://www.lifestyleclotheslines.com.au/clothesline-spare-parts/hills-70m-polycore-replacement-pack-grey-FD903530
Here is the video on installing this clothesline as well in case this also helps.
Jul 27, 2014 | Hills Everyday Villa 37 Rotary Hoist...
Restring hills rotary clothes line
To restring the Hills Everyday 37 rotary clothesline FD88010 you are going to need a couple of tools which include a small screw driver and a set of cutters to cut the new line cord.
You will also need to order a pack of line, which for this unit would need to be the 70m pack from Hills. Here is a link to the line pack you would need.
Here is a great video on the process to restring the Hills Everyday 37 rotary clothesline FD88010
If you need to access the Everyday 37 manual you can do so here and download it.
Hills Everyday 37 Rotary Clothesline Owners Manual FD88010
Hills line clips could be something that you may also need in the restring process as these do tend to break on the older models of this unit. Below is a link to the Hills line clips that fit the Hills Everyday 37 FD88010 model.
Hills Rotary Clothesline Line Clip Pack of 6 FD902506
Jul 19, 2014 | Hills Everyday Villa 37 Rotary Hoist...
Re-stringing a hills clothesline
I've looked at photos of the Rotary 6, and what I did with mine seems relevant, so..........
Dec 30, 2013 | Hills Rotary 6 Clothesline, Ocean
Replace latch
www.hillshome.com.au/spare-parts
Dec 22, 2013 | Hills Everyday Villa 37 Rotary Hoist...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
