Question about Refrigerators
Need instructuions to hook up 3 in 1 relay to whirlpool refridgerator supco urc0810
3 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: Wiring hard start capacitor in GE refrig
I would go back to person who gave that advice because just the right touch on that capacitor and YOU my friend will be in the hospital. If this is helpful, please post as such. TY
Posted on Jan 17, 2009
  • 884 Answers
SOURCE: Supco wiring an old freezer. Orange wire?
Was the orange wire on a switched live on the old compressor connections? It may come on when the compressor goes off in that case. If not, recheck the schematic for the other end of the heater. If it has a neutral, join the orange to the live feed to the supco. If it has a live, leave the orange on the neutral of the supco.
Posted on Apr 21, 2012
Testimonial: "Thank you!"
Emerson model#CR519B. The unit just stopped working. If plugged in a motor runs for about 8 seconds and clicks off; about a minute later it repeats. Help
I had the same problem with a small wine cooler. It happened to me twice in 6 years. Both times I had to replace the starter relay.
I couldn't find any repair facilities willing to work on these small wine coolers or refrigerators, probably because the bill would be more than the used fridge is worth. If you feel confident around a volt/ohm meter and electricity, you could learn how to test this and maybe fix it yourself.
You shouldn't do any of this if you aren't familiar with using a Volt/Ohm meter and can safely and confidently work around electricity.:
  1. Unplug the fridge
  2. I first tested the compressor with an Ohm Meter (see how with youtube video below or by reading how at Davesrepair.com). It was good, but it kept starting and stopping within a few seconds.
  3. Basically my starter capacitor/relay wasn't working. It supplies temporary starting voltage to the starter relay in the compressor, then cuts off to allow the motor to run.
  4. I bought a Supco 3-in-1 on Amazon for less than $13 and hooked it up according to the supplied instructions. It lasted about 3 years.
Of course, the factory recommended repair is to buy the original replacement relay, but it will be more costly and harder to find.
I bought a Supco 3 in 1 Hard Start relay sized for the HP on my compressor. Mine was the Supco RCO810 (see link below).
NOTE: Before I replaced the starter relay and overload protection with a Supco 3 in 1, I learned how to test the compressor with a Volt/Ohm meter. If you don't have a meter, you can buy them online or inexpensive to free with a coupon at Harbor Freight.
Feb 15, 2015 | Emerson Refrigerators
My refridgerator stop getting cold i tested the compressor and showed it is in good shape i would like to hard start it to see if it would stay running how would i hard start the compressor
Installed 3n1 start kit - did not help. compressor shows good resistant between all windings, not grounded, but hard start kit did not start it either. But this video might help You to wire 3n1.
Oct 29, 2013 | Stainless Cal Flame Refridgerator Steel...
Apr 21, 2012 | Refrigerators
Compressor stops running and keeps cycling every few minutes. It buzzes as if the compressor is gone. the compressor is hot. If the thermostat is turned to off for 6 to 8 hours and then turned back on the...
you can replace the relay with a 3 in 1 made by supco. i generally just use a supco 0410.
www.supco.com
it is a start relay, overload, and start capacitor all in one. works great for residential systems.
Nov 06, 2009 | Frigidaire FRS3R5EMB Side by Side...
Compressor problem, installing the Supco 3-in-1 Relay
Hi, If the 3 posts are top center and bottom right left, the black wire goes top the top center post. The red wire will go to the bottom right and the white goes to bottom left.
If the posts are bottom center and top right left, the black goes on bottom center and the red goes top left. The white goes top right.
If you do not see a capacitor, disregaurd the wires in the 3-1
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
The compressor starts, (or tries)for ~ 3 seconds, stops. retires ~ 15 seconds.
You either have a problem with your compressor start relay/overload assembly.......or you have a bad compressor. You would need the model/serial number for the correct part. If the unit is out of warranty, a 3 in 1 hard start kit (Supco URCO41) can be installed. Disconnect unit from power prior to attempting repair, and follow the instructions with the part.
If the product is under 5 years, the compressor may still be under manufactures warranty. In that case attempting a repair would void the warranty.
Jun 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
1991 Subzer 550 refridgerator/freezer needs new fridge relay/over
Check the refrigeration pages...
http://www.supco.com/ProductCatalog2004.htm
May not be an exact replacement, but a proper match should do.
Apr 08, 2009 | Refrigerators
Jan 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Not cooling
The clicking you are hearing is your overload on your start system sounds like your compresser start ststem is out..or your compresser is locked up the only way to tell is to ohm out the compresser idf you dont have a meter you can install a start kit like a Supco Pro41 or a RCO410 or a factory replacement and see if it starts up the compresser.. Have you cleaned the condenser at all ??? although this will not fix the compresser it can be a cause of overheating..The part Number you need is a 2188831 for the factory replacemenet ($22.56)the supco parts part number SU RCO410 ($15.00) the Pro41 is part #
SU PRO41 ($17.97) you can get them at your local parts house they are all easy to change or if you dont have a parts house close you can oder it on the web at www.apdepot.com Hope this fixes ya
Feb 17, 2008 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
