Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How to fix start button on whirlpool cabrio wtw6600
Whirlpool cabrio start button broke on washer
SOURCE: whirlpool wtw6200 cabrio washer error message f 51
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Posted on Jan 01, 2009
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool CABRIO WTW6400SW2 Washer shows F1 code
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool cabrio washer keeps flashing code F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Posted on Sep 28, 2010
How do I remove the start switch from whirlpool wtw6600?
The start switch is an integral part of the control panel main board.
Dec 08, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Piece behind start button broke and washer won't run.
Bonjour, le probleme et tres grave vous avez sappelle CRTL et FN
Feb 17, 2010 | Washing Machines
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have the exact same F1 code problem
Primary Control Failure
F
then 1 flashes when there is a primary control failure. Replace the machine control assembly.
This was under recall last year.
Telephone Whirlpool at 1-800-253-1301. Whirlpool has acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600 series washers.
Tell them that your Whirlpool Cabrio washer has been receiving the F1 error code repeatedly, with the same symptoms as reported by hundreds of other customers online. You were told that there is a recall for this known defect in the control board, and are requesting that Whirlpool fix the problem including parts & labor.
Be sure to get the authorization code from them so the service person cannot argue about costs.
Basically - this is a problem (faulty chip) on the main controller board of the unit... and the entire board must be replaced with the updated version.
Give the warranty a try (even if it is out of warranty)
CLICK HERE to see the part that is going to have to be replaced.
Aug 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer has a f1 code will not spin or wash
OK, your unit is quite unique. this unit has a integrated control design that houses the main and motor control board. both are combined on the same board. this error code represents a failed Machine and motor control board. this single control board works as the main controller and, as the motor controller as well. This board has failed in your unit and, you will need to replace this board asap if possible.
May 30, 2009 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
