My baird x37 powers up but the screen stays blank
The blue power light comes on but the screen wont
  • 98 Answers
SOURCE: Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Posted on Jun 09, 2008
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
  • 608 Answers
SOURCE: TV went blank with no
The "TV shuts itself off" or "TV won't power on" problem in the Philips 42PFL5432D/37 HDTV is due to a faulty Power Supply Board, # 715T2432-2. To be more specific, bad electrolytic capacitors on the PSB cause failure problems. These caps most likely failed due to a lack of preservatives that protect the caps integrity.
First and foremost make sure your warranty is expired as this procedure will void it.
Perform At Your Own Risk:
It never hurts to take pictures for reference purposes.
1. Remove TV from stand or mounting device and place screen down
2. Remove back panel of your TV by removing screws from the perimeter, middle and side AV. Lift back of the TV off and locate the PSB (the board that the power cord plugs into) PSB #715T2432-2
3.Visually inspect individual capacitors (C951, C952, C953 rated at 1500uf at 35V and C955 rated at 2200uf at 16V) for bulging or leaking. Even if they show very little sign of or even no distortion they may still be faulty.
4. Disconnect wire harnesses. Remove screws holding in the PSB and remove it from your TV.
5. Loosen the glue holding C951, C952, C953, together. Gently pry them apart. They will kind of snap apart. C955 also has glue between it and a smaller cap next to it. Be careful.
6. Turn PSB solder side up. Use a soldering iron to remove caps. A small soldering iron works best as you will have more control. Heat the individual posts/leads of the caps one at a time, melting the solder. Use one hand to keep the soldering iron on the lead, as you reach your other hand under the board to wiggle the cap you are removing. You won't be able to remove the whole lead at once. Heat one lead; back it out, then the other and back it out. Using this walking action will help make sure you remove the caps without damaging other components.
7. Install the new caps by soldering them.
Make sure that caps are installed with the correct polarity + to + and - to-. It is crucial. Both the caps provided, and the board is labeled. Thread the leads through the appropriate +or - terminal in the board. Get them as tight to the board as you can. Clip the obviously to long leads to about 1/8 in. Bend the leads down on the board to help secure the cap to the board. Solder the leads to the board by heating the lead first, and then add solder.
8. Reinstall the PSB and reassemble the TV. Remember to reconnect the wiring harnesses. It is best to test the TV with the back panel at the very least covering the TV.
Caps can explode if you have installed them incorrectly or if there are other serious power problems that caused it to fail in the first place.
Good Luck.
Posted on Dec 18, 2010
SOURCE: My 50 inch Hitachi plasma 1080 tv has a blinking
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Posted on Feb 08, 2011
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
LG 37LG30 wont come on. Gives blue light, but screen stays black and no sound
Sounds like the problem could be in the power supply of the TV. Have a technican check for defective capacitors if you're not equipped to do the job yourself.
Apr 22, 2013 | LG 37LG30 37 in. LCD HDTV
I have a baird x47dtv and we turned it on today but had no picture or sound. the blue power light comes on and flickers as it should on startup of tv,however we are still not recieving a picture. i have...
tried to disconnect first the supply voltage of the inverter board and then turn on the tv. if the indicator stay which mean the inverter board would be the cause of shut off or the tv turn to safety mode.
Sep 07, 2012 | Televison & Video
When i switch on my baird 37 inch flatscreen the screen is bright blue
The blue screen usually means no signal of any kind--check connections.
Also look to see if a DVD etc. connected to a rear audio/video input works or not--this will narrow down the area where the issue is.
May 16, 2012 | Televison & Video
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
