Question about Lenovo ThinkPad R61 7733 Notebook
Touchpad not working
How to enable my touchpad???????
  • Lenovo Master
  • 7,627 Answers
This may help:http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67760
Posted on Dec 07, 2012
Touch pad scroll gestures very intermittent.works then doesnt
Hi tommymul6...
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 04, 2011 | Computers & Internet
The touchpad stopped working with a symbol coming up on the screen indicating that the tocuhpad has been disabled. A yellow light indicator is also on by the touchpad. How can I enable it again?...
If you have windows installed you can go to "Control Panel." Select the "Device Settings" tab and click "Enable" to enable the touchpad. Click "OK" to save the changes.
If that does not work. you can press the touchpad for 5 to 10 seconds.
Apr 26, 2011 | HEWLETT-PACKARD ProBook 4320s C Notebook
How to enable touch pad operation in ubuntu 10.04
Ubuntu provides configuration of the most common touchpad options in System > Preferences > Mouse, under the Touchpad tab.
Try the touchpad after unchecking the Enable mouse clicks with touchpad check box.
Check operation after Enable horizontal scrolling is checked. This may not have been the default setting.
Disabling Touchpad while Typing
  • Go to System > Preferences > Mouse > Touchpad and uncheck 'Disable touchpad while typing' and 'Enable mouse clicks with touchpad'
Feb 15, 2011 | Dell F3534 Touchpad
Any way to turn off touchpad when typing ,etc
« Free Up Windows 7 RAM - Memory Cleaner Enable Administrator Account In Windows 7 » Auto Disable Mouse Touchpad When Typing By Nakodari on Nov 25 2009 28 Comments
It is a common annoyances with netbooks and laptops which lack the disable touchpad button. Most blogs out there are covering a single method to disable the touchpad, i.e, go to Control Panel > Mouse Properties and then disable the touchpad from there.
The above method is not suitable for those who need to disable the touchpad frequently for short periods of time. Who in his/her right mind would navigate back and forth just to enable/disable touchpad? This could be quite a hectic process.
TouchFreeze is a brilliant little app that solves this problem. It disables the touchpad temporarily the moment a keystroke is pressed. In layman's term, it disables the touchpad automatically when you are typing and enables it back when the typing is stopped.
It will sit silently in the system tray without disturbing any of your work. Just start typing and don't worry about the touchpad any more.
touchfreeze.pngI prefer using this app even though my notebook has a disable touchpad button. Please note that this app might not work with certain laptops, but should work with most netbooks and laptops that lack the disable touchpad button.
Download TouchFreeze
http://code.google.com/p/touchfreeze/
Nov 13, 2010 | EliteGroup 557 Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Toshiba M35 S320 touch control buttons have stopped working. How do I fix it?
The TouchPad is enabled by default. To change the enable/ disable TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click the Mouse icon. 4 Click the TouchPAD ON/OFF tab. The TouchPAD ON/OFF tab view window appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply. 7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window. 9 Close the Control Panel window.
However, still if it does not work, you need to download drivers for touchpad.Here is link to download the drivers for touchpad. Under the "All categories link choose Touchpad"
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=556040&rpn=PSM30U&modelFilter=M35-S320&selCategory=3&selFamily=1073768663
Mar 27, 2010 | Toshiba Satellite M35-S320 Notebook
My mousepad's scroll feature is no longer working after I took my laptop to Best Buy and had them install a new harddrive under warranty
Right above the Touchpad is the On/Off button to Enable the Touchpad, or Disable the Touchpad.
If the Touchpad light is on, then the Touchpad is Enabled. (The On light is right above the Touchpad also)
Do you have the Touchpad enabled?
Dec 12, 2009 | HP Pavilion dv1000 Notebook
Touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Oct 19, 2009 | Fujitsu LifeBook A6120 Notebook
Touchpad inactive
is there a small button near or on the touchpad, most laptops have a small button that enables and disables the touchpad just by pressing it.
Jan 13, 2008 | Acer Aspire 5630 Notebook
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Lenovo ThinkPad R61 7733 Notebook Logo
77 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
