Question about Samsung RB2155 Bottom Freezer Refrigerator
Freezer has quit compleatly
During a kitchen reno I moved the fridge to a new spot ....when i pluged it back in the freezer just kept getting warmer and warmer!! Now its thawed everything and wont cool at all............
  • 45 Answers
Could need freon. Could have a bad thermostat. Could just have a leak, which is the easiest to fix, check around all the edges of the door for any deformed stripping or openings, if it is, just go to a hardware store and buy some more stripping, otherwise call a repairman or buy a new fridge
Posted on Jan 12, 2009
LG model LFX21960ST. No cooling in either fridge or freezer. The compressor comes on for about 7 seconds when first turned on and then will cycle on for a few seconds every few minutes. The fan in the...
There could be a loss of freon(unlikely but possible), the start capacitor for the compressor is bad (most likely) or the thermal cut off switch on the compressor is cycling from the hot compressor.
Mar 28, 2017 | LG Refrigerators
We moved a 2004 whirlpool fridge it was cold before we moved it and now the fridge part is luke warm and the freezer is getting warmer. Help please
When we transport a fridge we try to keep it always at a verical position and if this is not posible and need to be horizontal then after we put in place we have to leave it for 12 hour relax before we switch it on so the compressor oil will balace on the bottom and thus full lubricate the compressor motor parts.
Now There is another option that during transport have created a leak which this is the worst case.
So can please describe the timing of the transport , how long it stay relax after the transposrt and how long you have it on now and what temperatures you have in freezer and fridge. Also the also the model of the fridge
Aug 28, 2011 | Whirlpool Gold GR2FHMXPQ 21.6 Cu. Ft....
During heavy frost everything froze solid even drainage pipe. I notice that my freezer (top half) is not cooling at all. All food has gone soggy. Fridge is just cool.Will it right itself once kitchen...
It's possible the unit is not working correctly as it expects the air temperature to be around 18 degrees centigrade. If too cold, they can go into a defrost cycle.
If your food is not cold enough - but your room is frozen - can you pack your freezer items in snow? Alternatively, move the unit to a warmer area.
Sounds strange - but modern units don't work well in the cold !
Dec 25, 2010 | Refrigerators
Refrigerator/freezer stopped cooling during a heat wave
Good day,
Turning the thermostat to a warmer setting should not have caused the machine to quit cooling. Actually, the engineers give you far less leeway than you might think.
The controls are more in a class of fine tuning, otherwise people would be getting themselves into trouble. The manufacturers simply design the warm and cold parameters in a fairly narrow range.
The best setting is normal. When away, the machine will run far less simply because of no door openings. Opening a door lets in large amounts of air every time it's done, which is where your cost to run it exists.
Two things. One, if the temp in the kitchen exceeded 90 degrees for any length of time, you are operating it beyond it's design range, however two, it sounds as if the thermostat hung up, causing your issue. You may want to have it replaced, but it would be useless to call anyone when it's performing normally.
There is no test on thermostats other than by observing their action when the machine is not operating properly.
Jul 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator side getting warmer. Freezer seems ok. Recently there has been a lot of things added to the fridge side and it is quite full. I wonder if Something is blocking something but I can't see...
It is all rightt if the heat is just warm . This is so becasue your fridge exchanges heat for the cycle of gas being compressed and released that eventually cools your freezer. earlierr fridges had the coils on the back side which was open but now they are mounted on the sides with glass wool packing. Hence if your freezer and functions seems alright just see that the thermostat is not kept too much and allow the fridge to shut down frequently so that the coils cools by heat dissipation. I hope my advice is helpful Good day
Jun 22, 2010 | Frigidaire FRS23R4A Side by Side...
When the fridge is turned on, it begins to beep constantly and does not stop until we switch it back off. We had moved the fridge about because we were shifting it to the kitchen and there was water...
HI, this beeping is signaling an issue that concerns the main control board. The control board may have sustained some serious damage during the move. Have it replaced asap. This spillage may have dripped onto the board itself, thus, causing a short when power was introduced after the unit was settled in its new arrangement.
You can visibly inspect the board for water damage or burn marks on the circuit layout.
Sep 30, 2009 | Hotpoint Refrigerators
Mini Danby Fridge Won't cool but compresser is running very HOT!(Model DCR412BLS) the fridge has just recently been moved into a warmer environment without air conditioning. As well, it had accumulated...
never turn a fridge up side down and when moving a fridge or freezer keep it upright as much as poss and dont plug back in for leave it unplugged a buy new one...
Sep 14, 2009 | Danby DCR412 Compact Refrigerator
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way I purchased a Kenmore fridge in Aug. 2005 (no freezer - fridge only). During a couple weeks...
assuming you have had the appliance unplugged for a while, plug back in and it may well work ok. if so, get back to me and i'll take it further
Aug 31, 2008 | Refrigerators
Refrigerator isn't working anymore
Try to completely defrost it, then if the freezer works but not the fridge change the thermostat
May 31, 2008 | Kenmore Refrigerators
Samsung RB2155 Bottom Freezer Refrigerator Logo
134 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
