Question about Tissot Prc100 T22268631 Watch
Why my tissot prc 100's second hand stops sometimes then runs very quick afterwards?
3 Suggested Answers
  • 183 Answers
SOURCE: Tissot PRS 200 hour and mnute hands not advancing.
I may not be clear on the problem here but it sounds like you may only need a battery change. If the battery is not the problem you can ask that your watch by placed on a cyclonic to force the gear train and free up small particle(s) that might be holding it up. This will be the fastest and least expensive. There is the chance this may require a more complicated repair but this till give you a starting point.
I suggest going to a watchmaker/technician who is familiar with working on this brand and be able to seal the watch back to its water resistant rating. This will take having a pressure chamber on site.
Posted on Sep 25, 2009
alpug
  • 1961 Answers
SOURCE: I own a Tissot chronograph
hello!
first of all you need to synchronize your watch
Advice on how to synchronise your watch:
To synchronise the seconds hand (3) with an official time signal (radio, TV, Internet), pull the crown into position III ; the seconds hand stops at this point.
At the tone, press the crown back into position I (and tighten it down if you have a model with a screwed crown).
Fast correction of the date* and day*
Important : Do not set the date* and/or the day* between 10 pm and 2 am (the movement is in the process of changing the date at these times).
Pull the crown into position II and turn it clockwise until your watch display the correct date (4) and turn it anticlockwise to change the day setting (5)*. During this operation, your watch will continue to function normally, so you will not need to alter the time.
Posted on Jul 16, 2011
I bought a Tissot prc 200 quartz chronograph a month ago and it suddenly stopped working. Can someone please tell me what's the problem?
Well, I go to a jewelry shop called fast fix and purchased a "forever battery " most obvious answer is that the battery is simply dead. Second, there may be debris in the clockwork, which will also kill the battery. Good thing about the forever battery method is that they will clean out the watch for free usually, which saves on them replacing the battery.
Feb 06, 2015 | Tissot Watches
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
I have a Tissot PR 50 Chrono,,, I have replaced the battery 3 times in the past two years. Then it got to where the second hand only would run. Now, nothing. If I hold the lower button in, the second hand...
When a battery is replaced, but doesn't last long, that indicates an internal electrical problem with your watch. The fact that the hands are operating incorrectly is also an indicator that something has shorted out inside the watch. I wish whomever sold you batteries 2 & 3 knew what they were doing!
As the Tissot is a fairly expensive, quality watch, I would suggest finding a locally-owned, high-end jeweler to recommend a watch repair shop, or alternatively, go online and Google "Tissot repair" to find an authorized repair shop. Good luck! Sorry I couldn't help you.
May 03, 2011 | Watches
My prc 200 is not working maybe its the battery?
These watches are "automatic" which means that the are self winding.
They will run for 1 -2 days before stopping. Shake the watchgently from side to side for a few minutes and it should start again.
(These watches need to be constantly used to keep them working).
Dec 12, 2010 | Tissot PRC 200 T17.1.586.32 Watch
The second hand on my Tissot stops for a while and then jumps forward the time is fine what could be wrong with it?
Most likely it is the low battery indicator. Changing the battery will solve the problem
May 21, 2010 | Watches
The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Dec 20, 2008 | Watches
Tissot PRS 516
Your Tissot watch is a chronograph. The large second hand is for the stop watch only. There is another second hand by the six that is for the time. To get the large second hand to move hit the top right button, that works the stop watch. If you already knew this and your large second hand is not going around then there is something wrong with the watch either a battery or needs service.
Mar 08, 2008 | Tissot PRS 516 T91142651 Wrist Watch
How do I use my watch???
I also own a PRS200. The two buttons on the right and top two subdials are for the chronometer function.
The top right button starts and stops the chronometer function: First press starts the chrono. Second press freezes/stops it, so you can record your time. Third press resets the chrono.
The bottom button is for the lap function: on the first press, it freezes the chrono in order for you to be able to record your "lap time", but keeps the chrono running in the background (you don't see this, it's the movement that does this mechanically). When you press it a second time, it jumps back to the running chrono time. You can then press it again to get another lap time, and so on...
In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Feb 23, 2008 | Tissot PRS 200 Wrist Watch
Tissot Prc100 T22268631 Watch Logo
76 people viewed this question
Top Tissot Watches Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Tissot Watch Expert? Answer questions, earn points and help others
