Question about Hotpoint Dishwashers
Hotpoint FDW70 dishwasher error code A02
Error code A02 is flashing
Joe_Rex
  • 114 Answers
SOURCE: I have a Hotpoint FDW70 dishwasher
Disconect POWER at breaker or fuse panel which should be on a seperate braker. if not find the power sorce and unplug the device. FOR SAFTEY Kneel on a thick doormat if you have to disconect power which has a plug. Wait for a an hour so to let all circuits, timers and motors to cool ... with diswasher in the OFF position, Re-establish POWER. then go ahead and start washer as sugessted by the Manufacturer. Make sure to notice any other codes that may appear. Or any peculiar noises. Most default codes appear if water pressure is too low. Top loaders are natorious for plugged drain lines and can be flushed by the home-ownwr. Make sure to check that water strainer is not cloged or restricted. Hotpoints CODES change from year to year, You can contact a Hotpoint Dealer in your area ... Give him the Make, Model, and any Series numbers to him. MOST will tell you what the CODES ARE FOR THAT MODEL OR EVEN E-MAIL ALL OF THEM TO YOU. Good Luck ... Be Safe Joe Rex
Posted on Oct 09, 2007
SOURCE: hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Posted on Feb 23, 2008
SOURCE: hotpoint bf162 built-in dishwasher error codes
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Posted on Mar 07, 2008
SOURCE: hotpoint fdw85 dishwasher error code al10
Hi we've got the fdw80 and AL10 is the heating element. Ours goes wrong every couple of months luckyly we've got extended warranty till 2011. They wont replace machine as fixable so they will be coinng out every 2 months for the next 3 years.
Hope this helps
Posted on May 12, 2008
SOURCE: Hotpoint FDW 85 Dishwasher
You just need to switch the machine off for approx 30 seconds from the mains and switch it back on again!!
AL99 means that there is a communication error within the machines software.
Posted on Jun 16, 2008
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Dishwasher not doing anything
hi does anyone know what error A06 for the Hotpoint Aquarius FDW70 means and if it can easily be fixed
Jun 13, 2013 | Dishwashers
A06 fault code hotpoint FDW70
hi does anyone know what error A06 means and is it fixable
Aug 31, 2012 | Hotpoint Dishwashers
Help my Hotpoint FDW70 iS FLASHING a99...............Many thanks Sarah.
A99 is a communication error. Try unplugging your dishwasher for 10 minutes and then try it again. If you still get an A 99 code that suggests a problem in the control board in the dishwasher. In this instance I recommend an engineer as it can be extremely difficult to fault find this error.
Hope this helps.
Mar 09, 2011 | Hotpoint 24 in. FDW60 Free-standing...
My Aquarius FDW70 keeps coming up with code A10
Dear sir,
If your dish washer is type EV02 Module,
Error A10: means Faulty fill valve.
Check valve and associated wiring.
If your Dishwasher is
Standard Module + FDW70 + FDW75,
E10 means Heater fault.
Check heater and associated wiring.
i think it helps for solve your problem.
if you have any doubt regarding this issue leave a feedback we will glad to assit you.
Have a nice day
good luck
Sep 12, 2009 | Dishwashers
How do i find the float switch for a Hotpoing Aquarius FDW70
Open the DW. Look in the front right or left corner of the tub.
You will see a plastic dome.
The float switch is directly underneath the dome.
Remove the toe kick plate and located the float switch from the bottom.
Sometimes they get stuck.
Jiggle it then try the wash cycle.
If that does not work, replace the float switch.
Feb 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My aquarius hot point fdw70 comes up with error a10
Check out www.selfix-uk.co.uk for all hotpoint error codes and what they mean
Oct 07, 2008 | Dishwashers
Hotpoint
hope this helps u... all the error codes and faults, they can be found here>>>>>>> http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
please vote thankyou
Apr 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotwpoint not working
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • Mar 07, 2008 | Dishwashers
    Hotpoint Aquarius+ FDW70 Error Codes
    i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
    May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
    Dishwashers Logo
    102 people viewed this question
    Top Hotpoint Dishwashers Experts
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
